Coloradored
Toyota Tacoma 2012 TRD Sport - 122000 miles - $25000 - Grand Junction Colorado
(The Good)
This Toyota Tacoma is ready to go. It has all the goodies that will take you on all the adventures. ARB front bumper and a custom rear bumper that was built around moving bikes and high clearance departure angles, with custom swing out and back up light. The Old Man Emu BP-51 suspension has full adjustability with rebound and compression control. Matched with the Dakar leaf springs and Timbren Active bump stops you can easily move full loads across rough terrain. There are plenty of lights making it always easy to see. Pia headlights with Rigid Industry LEDs front and rear. I also upgraded the battery with a larger than stock deep cycle AMG and the wiring to match. A stand alone wiring harness with switched relays has plenty of room to grow for future accessories. The custom rack can be used for moving anything from lumber to raft frames or roof top tent. I've been the second owner since 65365miles. I have most of the service history from the original owner and I have a very detailed service history since the day I brought it home.
Specs
Double cab 5ft Bed
V6 4.0
6 Speed Manual Transmission
Old Man Emu BP-51 Suspension
Old Man Emu Dakar Leaf springs
Timbren Active off road bump stops with U-bolt flip
ToyTec diff drop
East Coast Gear Supply Clamshell bushing kit
Deep Cycle AMG Battery with battery terminal wiring extension
Stand alone relay wiring system
New clutch & URD throw out bearing upgrade
BFG K02 285/70/17 on TRD PRO rims (108781miles)
ARB front bumper
Custom Rear bumper with 1up Usa Bike Rack
Rigid Industries (driving pair, 6in supper spot and defused rear)
PIAA headlight bulb
Weathertech floor mats
Covercraft rear seat covers
Hypertech speedometer calibrator
Factory TRD Sport stereo with BlueTooth
Factory backup camera (Relocated for bumper)
Recent service at 120518miles
Lower Ball Joints and control arm replacement (OEM Toyota)
Rear Driveshaft rebuild (DANA Spicer)
Clutch and URD throw out bearing (Aisin & URD)
Warranty replacement of OME BP-51
(Bad/ugly)
There are some dents. The truck is just about perfect, but since i used it for what it was built to do there are some dents. Passenger side rear fender came in contact with a bush after slipping into a ditch on a slick dirt road. Also the rocker on the driver side rear door has a dent after getting high centered on a sharp turnaround on a dead-end mining trial.
Im asking $26000, but if you aren't interested in the tent or bike rack i can come down in price ($1000Tent, $500Bike rack)
Please feel free to ask questions!
(The Good)
Specs
Double cab 5ft Bed
V6 4.0
ToyTec diff drop
ARB front bumper
PIAA headlight bulb
(Bad/ugly)
