Hopeless Diamond
After watching the episode yet again (compared to most things on TV, I'd rather watch a re-run of that vs. a re-run of the other crap), I began wondering about the cinder hill sequence and why the LR did so much better than the other vehicles going up it. It seemed to not have any issue in the loose stuff, where the Brute seemed to struggle more and just muscled it's way up. It obviously wasn't power, otherwise the Brute would have fared better. The FJ eventually did make it up but it struggled from the beginning. It's not like the LR is that much lighter, it's probably 1000lbs lighter than the Brute though. If it was weight, the FJ should have done better. Tires (and driving style) probably didn't help the Brute but it's not like Tanner was light on the throttle with the LR. I'm assuming no lockers in the FJ which was probably part of it's problem. Of course, the route up the hill could have been part of it too, it was hard to tell but it looked like the track the LR used was more compacted where the other 2 went up was very loose. Or, is the LR system that much better, and if so why/how?
