Gently Used 2019 Oregon Trail'r DoDrop Alpha Teardrop Trailer loaded with most all of their options. Nothing wrong with this trailer, still smells brand new inside and out. Used only twice and stored mostly inside out of the elements. It is in great condition. Check out this huge list of included gear. Asking $17K.
If you know trailers, you know how bulletproof baller Oregon Trail’rs are. The Alpha is their most capable off-road trailer, period. Construction is baltic birch, dado joints for strength, coated liberally with impervious Linex, all mounted on a steel frame with over-engineered long-travel independent axles. R-15 insulation keeps the inside temperature comfy in the baking sun and cold nights. This thing will go most anywhere your rig can go from KOA to King of Hammers.
This trailer is ready to go tomorrow to your favorite camping adventure. California license plate transfers with vehicle, you just pay registration. Title is clean and crisp. Don’t wait months and month for a new build. Buy gently used and get going now!
Electrical system:
- Large capacity AGM battery
- Switched/fused panel
- 12 volt outlet, 5V USB ports, and battery monitoring inside
- Pass-through 110V inside
- 12 volt outlet outside on the back
- Charges from shore power, Zamp solar, and vehicle while towing
- LED ceiling light with MaxxAir fan
- Dimmable LED light strip
- Zamp solar panels and integration package (so you can go completely off grid)
Features and Options:
- Rear leveling jacks
- Black-out door curtains
- Generous 78” interior length, longer than your normal full size mattress
- Road Shower 7 gallon with hose and nozzle
- 82"x 54" Cascade Vehicle Tents awning
- Rola cargo basket
- Cargo management package (interior lash points and linex-coated floor)
- Front mount storage box with Rotopax mount point
- All LED exterior lights
- Nilite reverse LED lights (super bright for backing up into your campsite if dark out)
- Falken 235/75R-15 tires, with spare and cover, including set of wheel security acorns
- Timbren axleless suspension which provides 20 inches of ground clearance (more than your vehicle for sure)
- Max Coupler hitch with three key locking pins
- 7 pin hitch plug
- Electric brakes
- Weighs only 900 pounds so can easily be towed behind many different vehicles even without a brake controller. Hardly noticeable behind a Jeep/Taco, and also suitable for your Subi.
- All souvenir stickers are removable inside and out
Trailer is located in San Francisco Bay Area
Electrical system:
- Rola cargo basket
- 7 pin hitch plug
- Electric brakes
