brad2274
Been lurking on the forums for a bit, was originally going to get a square body suburban but changed my mind and picked up a 1996 montero ls. 165k miles, 4x4, It's a little rough but i only paid 1200 for it and the ac is ice cold so im happy.
Things of concern:
-Valve ticking noise, seems to be the valve slack adjustment thingy
-No maintenance records, previous owner just did oil changes, the belts are squeaking
-oil drip from somewhere
-driver front fender replaced and on that corner is showing bands on inner side and good tread on outer, pulls hard to left on highway with some darting. i suspect bad alignment with some negative camber from an accident.
So i was thinking of doing timing belt, drive belts, plugs, wires, valve cover gaskets, maybe head gaskets, check pads, and change all fluids. would like to make this a daily and camping
cargo net that doesnt look factory
i dont know what this is, ideas?
y idea
any idea what went hear? i see screw holes
took out the carpet right away and pressure washed it, one of the floor plugs was pushed through and water was in between carpet and floor, this is before cleaning, its drying now. i dont see any damage besides to the plug, may deaden floor more before reinstalling carpet and replace the soggy padding.
found these not going anywhere under the center consolole, for the optional heated seats i presume?
Things of concern:
y idea
