1996 Land Rover Discovery SE7 Manual
Tbacus
Located in Salt Lake City, UT
$4,000 OBO
Time to let my trusty Rover go. I have had this truck for about two years now and it has taken me to the back of beyond with no troubles. It is 23 years old, and not perfect, but I have kept up with maintenance and it has never stranded me. It is a rare factory 5 speed manual. I am basically pricing at the price of all the extras on the truck. Come and take a look.
The good:
All rust fixed
OME springs and shocks - gives about a 2 inch lift
Tru-track diffs front and rear
New 4:10 diff gearing
Replaced front and rear drive shafts
5 BFG AT KO2 tires. About 2/3 tread remains
Baja rack with Hella lights, fuel mounts and RTT mounts
ARB front winch bumper with Hella driving lights
Heavy duty steel sliders
Heavy duty steel rear bumper
Rear light guards
Rear ladder
Much of the electrical reworked: New clock, seat switches, radio
Alarm system disabled
Cold AC
Solid transfer case with center diff lock all working smoothly
520920
520922
520924
520926
520927
520928
520929
520931
520932
520933
The bad:
Did I mention its 23 years old?
The front swivles are leaking and should be replaced
Drivers door lock actuator fails intermittently
No syncro between 1st and 2nd. Still shifts fine once you learn when to shift.
Engine has 200K miles. It has the rover tick and could use a top end rebuild.
Hellas on the roof rack are not connected. I will include the wiring harnesses.
Cruise control disconnected
Rear AC disconnected
Sunroof disconnected
I have a number of spare parts, filters and fluids for the truck that I will include. Come give this guy a good home.
Tbacus
The truck had rust around the alpine windows, around the rear door frames and along the lower sills. It was all repaired by a shop in SLC that specializes in older restorations called All Star. After the repairs it Waxoyled to prevent further rust.
WonaWarrior
