wanderer-rrorc
titles wordy..but Im thinking this..
the 14ft enclosed trailer is for work/play. I put 12volt led lighting all around for site work (and maneuvering trailer in the dark). 12 volt strip lights inside for both camping and being able to work inside when its poor lighting.
I ordered a renogy 200watt kit. and a 100ahu battery, a power analyzer (to see draw). and Im sure I will probably grab a 4000watt inverter (or something similar)
That should let me run chargers and some low amp draw power tools. (almost everything is battery powered)..it will also let me run my CPAP when we are camping in the trailer..
I will eventually be setting up the house to use the setup to run some outlets in the house (and 22amp furnace blower) when we loose power..(and possibly in the future daily supplemental power to dedicated circuts in the house if it works well)
has anyone tried something similar? using your camp setup to pay for itself when your at home...
I know I will need to add more batteries and more than likely change the charge controler from the factory renogy one..
