Romer
I am looking at swapping my AGM batteries for Lithium batteries (LifePRO). My only concern right now is winter storage
I have a detached non insulated garage I keep my Karavan in. In Colorado there are days (not a lot) it gets below zero sometimes (rarely) below -10F. The temp in the garage may be warmer, but not much
The battery box is in a front external compartment that is not insulated
My AGMs are always plugged in and charging and have been OK for over 4 years. They are starting to degrade, why I am making the swap now
I understand with the Lithium you dont keep charging them, especially in cold weather. You charge them and let them discharge while not in use
I see that Relion makes a LT style cold weather battery
I was looking at Battle Born, Relion and I saw the Dakota batteries which also highlight cold weather operation
Cold weather storage over the winter for my Karavan and the impacts on the new batteries are my one remaining item before pulling the trigger
I am not a winter camper, but can see some nights getting down below freezing during the spring or fall
Hopefully that defines my situation and planned usage
Battleborn makes heaters that wrap the batteries, but with that I would have to monitor the charge
I could put an electric blanket in the battery box, but nervous leaving that plugged in in my detached garage over winter
Do I take the batteries out of the Karavan for Winter storage? Do I buy the Relion LT or look more into the Dakota Batteries?
or do I just disconnect the batteries and let them sit over the winter? the stated discharge rates would still keep them above 50% over the winter months
What do others do here and is there any other considerations?
Thanks in advance
Thanks in advance
