Winch turns one way only
kootenay
Intergalacticsuperintendent
I bought a warrior winch 9500sd and had it mounted to my Nissan Frontier for 3 years. Then one winter it stopped working. I had the motor rebuilt this winter by a starter motor guy. I have installed the winch onto my Jeep and I can get it to only run in one direction, counter clockwise when looking at it from the motor end. When I switch directions I get a click in the new Contactor but no movement.
Is this motor toast or could it be a wiring issue I messed up?
Thanks
I Leak Oil
These are simple 12V systems. Get a diagram and test light or, bettre yet, a meter, check power to the switch, power from the switch to solenoid, check the solenoid contacts, check solenoid to motor. Be methodical and it'll become obvious where the issue is.
With that said, I once had a toggle switch that showed to be good with a test light but was not letting enough current through to acivate the coil in one of the solenoids. In that case a meter finally pointed me to the switch.
blacklbzbeauty
There you go!
This forum is great for trouble shooting. So much institutional knowledge and willingness to share the same.
jgrillz94
