What do you put between your camper and truck bed?
SameGuy
Wondering what, if anything, people put between their camper and truck bed? I have heard of people using a horse stall mat or heavy duty truck bed mat. Does this keep a slide in camper more secure, add height, etc?
Atl-atl
Snap together rubber anti-fatigue flooring. Its like 3/4" thick and the camper does not move. Two fit my 6' bed perfectlyd. https://www.homedepot.com/p/Traffic...nti-Fatigue-Comfort-Mat-KFTRM9191-1/206355967
JaSAn
Grumpy Old Man
4' X 8' X 3/4" thick Owens-Corning Foamular (the pink stuff). Needed height to get over pickup bed side.
Very light, adds insulation, and moisture doesn't get between bottom of camper and the Foamular.
Mundo4x4Casa
West slope, N. Ser. Nev.
If you have the cab clearance, a 3/8 inch thick, sticky, fluted rubber bed mat is enough. The thick ones above will allow compression and expansion, rocking of the TC body, side to side on curves or undulating road surfaces and possibly in the arc of hitting your cab. Also, to contain the beast from sliding around, I use Lance camper Guides, essentially 4 metal triangles bolted to the bed, just wider than the base of the TC to keep the box from slipping from side to side. What's wrong with that, you ask? If the tie downs are tight it puts an extraordinary load on the stretched side.
Jasan, love the power wagon, with a winch no less.
jefe
deserteagle56
What the jefe said. Because I needed to raise the camper in the bed to clear the cab, I had to build a 3" high platform. To the top of the platform I glued rubber tool box liner which is thin but very grippy - the Bigfoot is all slick fiberglas and that keeps it from sliding around. And I attached camper guides to the side of the platform to keep the camper centered on the platform.
SameGuy
FWC Suggested I get a stall mat which I did. Think its 3/4" thick, not much give to it but it does raise the camper a bit giving me around an inch over the bed rails. When I take the camper off I think I will try to find a different solution. Ths mat is really heavy, guessing around 50-60lb. Every pound counts as far as the Tundras payload is concerned. I can see that it has a little grip on the camper, and probably soaks up a little shock along the way. Will def take a look at the Owens-Corning Foamular, keeping it light is very appealing.IMG_2616.jpeg
turbothrush
My experience with Formular on a narrow floor camper (Northern Lite 6"10') is that it will eventually compress under the front corners of the camper. The foam board I was using was Formular C300. I then switched to a heavy duty truck mat material available at Princess Auto (Canada) which I assume is similar to stall mat. It has some give to it but comes right back unlike the Formula. The rubber-like material is very heavy so I cut it into strips and used it in floor joist pattern to save weight.
I think if a person wanted to go a step further one could do a perimeter of stall mat or anti-fatigue flooring as post #2 with the Formular in the center for the extra insulation
Randy Towles
