Vario project "Camioncic"
pushlan
Hi,
I start to build my camper in 2015, and now is realy finish.
In 2014 I buy Mercedes Vario bed truck:
Now is:
Short video from test drive:
A_anu
Very good camper! By the way, I've seen that you have several solar panels, how many watts are there in the ceiling? regards
pushlan
I install 3 panels - total 750w power. In sunny days maximum output at battery - 20A.
In the frame I have 6 batteres 105Ah
Yes, I build it.
pushlan
Specs chassis:
* 4x4 fultime
* axle diff lock
* rear diff lock
* 2 speed transfer case 1:1.67
* whell base 3700mm
* 9.5R17.5 tyres
* 3 fuel tanks: 120+120+145 l
* front and rear air suspension
* additional generator 100A 24V on the engine
* 6 batteries 105Ah
* air system for tyres, kite, etc.
* front winch 12000lbs
* rear winch 18000lbs
* 90l black water tank
* 2x20l lpg tanks with electric valves in frame
* roof racks on cab
* roof lights
* engine heater 4KWt Eberspacher
* 2 big storages and 1 small in the frame
* underrun bar with two position - onroad/offroad
* 2" hitch receiver
Cab:
* 5 seats + drv
* two front seats isri with cushion
* cab air heater Eberspacher 4Kw
* two radios HF and UHF/VHF
* sony audio
* automotive LTE router
* inverter 220V 300W
* inverter 12V 40A for audio and radios
* air conditioner coleman match 13500 btu
* rear seats transform in bunk beds
Body specs:
* size 3300x2200x2100 mm
* bed 195x125 cm
* dinette for 3 pers
* table 140x80 cm
* water tank 650l
* water pump 17l/min + tank 8l
* inverter 12V 300w
* inverter 220V 300w
* inverter 220V 3KW
* solar panel 3x250W
* solar controller 30A MPPT
* air conditioner 13500Btu
* fridge 110l
* heater webasto 5Kw
* boiler for hot water 30l (heat from webasto or 750W electric ten)
* heater with 3 pos fan
* lpg stove with 2 burners
* microwave
* cooker hood
* dishwasher for 6 sets
* automatic wash machine 4kg
* shower 75x85 cm with portable toilet
* two big storages on left and right side (aprox 500+500l)
* awning 3.3m x 2.4m
* outside kitchen lpg stove with 2 burners and small oven
* two auxiliary shower on both side
* ventilation system with air filtration
ianc
Adventurer Wannabe
I really like your van.
Are you based in Chisinau?
I travel there fairly frequently for work.
