Bella PSD
I just picked up a koolatron used RV Fridge for $10. It looks just like a RV built in fridge. I would guess this came out of a pop up camper?? About 55 quarts big. Thermoelectric, of course. That’s the best way I can describe it. Looking for the model #?? Nothing on line about this fridge at all(Google search).
I know the Thermoelectric’s are not recommended. But I thought for $10 and the fact that it’s 55 quarts, why not. Only $10 to loose.
And maybe because it was made for a built in RV installation, maybe it will perform better???
I temporarily hooked it up today in the Flip Pac and it seems to work well.
So far, here is how it doing.
6:45pm turned on at 79 degrees ambient
7:45pm 49.5 degrees 74 degrees ambient
8:45pm forgot to check
9:15pm 39.5 degrees 70 degrees ambient
10pm 34.5 degrees 68 degrees ambient
10:30pm 28.1 degrees 67 degrees ambient (below freezing !!)
10:31pm Turned the thermostat down until the unit powered down.
I think this would be a 6 setting out of 10 on the dial, 10 being the coldest. Its now 3am and it has kept a steady 31.9 degrees for 4.5 hours. So far this Koolatron fridge DOES out perform my Absorption Domtec fridge on AC power power!
I am going to let it run till the battery dies. We’ll see if it’s days or hours?? Total run time so far, 8 hours. Keep in mind the fridge is empty, so this will not help. But I am trying for a worst-case test. If it makes it to see sunrise, I will roll the camper out in the sun with the windows shut. Reporting back after I get some sleep…IT’S 3AM:coffeedrink:
Louie
Louie
