trailscape
I guess it's time to update this thread. This has been kind of an ongoing project since purchase in 2013. The build itself never had a plan or goal in mind, but was to be more of a "learn as I go".
I wasn't sure I actually wanted a trailer, so purchasing a more expensive and fancy overland style one didn't seem to make sense. Also, I've found I often need a simple trailer for various projects.
I came across this back in May of 2013. It's a 4x8 single axle with a 2990 GVWR and 400lb curb weight. Spring under axle, 15" tires. Priced at $650.
It's rather stout using square tubing all around.
I'd need to enclose the sides, install some kind of lid or cover.. I may even go to extremes and put a slide in camper on it if possible or attempt to build my own.
As of June 2018. The trailer has seen a number of configurations, some much uglier than others.. It's been a good learning experience.
I never had any intention of using this with a tent, so the lid configuration was more of convenience. The dual lids continued while nearly everything else changed.
Both lids are easily removed to keep the trailer multi-purposed. I added racks for those Home Depot runs.
