Squat can be corrected with Air Bags, and they are a good addition, but a lot of the trailers I see on the trail, have way too much tongue weight, some in the 400 pound area. If you are building your own trailer, keep the weight where it needs to be. Also for the trailer to tow properly the front should be 2 inches lower than the rear, not even. You can have far less tongue weight by having the trailer balanced. Keep the batteries low and too the center of the trailer and have the water tank under the trailer over the axle. That makes the center of gravity low and centered.
