Arclight
SAR guy
Hi all,
I'm trying to fine-tune my box of off-road fixing supplies. Currently, I've got everything in a large Contico box with wheels. Most of my off-roading experience was with my old Bronco and fixing other people's trucks who didn't take care of maintenance. The Toyota-specific stuff is new to me, so I'm looking for input.
The top things I've had to fix over the years include:
Any other experiences to add? I'm thinking I might pick up a starter contact rebuild kit, since this has never been done on my truck. Does anyone carry any other electrical spares or similar? Special tools for the 5VZFE?
Thanks!
John
- Tires (Punctures from sticks, embedded rock, nails)
Fix: Plug kit, good compressor. Can combine plugs for more coverage. (Not so great on the highway) - Tires (cracked valve stem from poor maintenance/desert storage)
Fix: Duct tape, spare tire, trip to tire shop. - Tires (Sidewall rip/damage requiring change)
Fix: Good breaker bar or 4-way wrench. Check torque after tire monkeys work on truck. - Battery (Simple jump start from leaving lights/radios on, hole rubbed in case from broken mount, shorted plate)
Fix: Good jumper cables (4ga copper). Low-voltage disconnect. A portable booster is another alternative to dual-batteries and/or cables. - Check Engine Light (CEL)
Fix: Scangauge and shop manual - Belts (worn out, damage from something getting sucked in)
Fix: Keep old belts from changes, sockets and wrenches to change. - Rear u-joints and strap (Seems proportional to the size of tires, engine and gears. Lockers don't help)
Fix: Spare u-joint and strap, vise grips, wrenches, sockets, needle nose pliers, large socket and something to beat it with. - Plugged fuel filter
Fix: Don't buy gas in Mexico. Spare fuel filter and open-end wrench to change. - Rear drive shaft - other joints
Fix: Wrenches and sockets to remove and stow rear D/S. Drive home with front wheels in 4HI. - Hoses (power steering, radiator)
Fix: Keep spares from changes. Use silicone hose-rescue tape. Duct tape is worthless for pressurized hoses, IMO. - Flooded engine (aka spectacular water crossing fail)
Fix: Drain oil/water from crankcase, dry+recharge battery with jumper cables, pull spark plugs and turn over engine. Carry spare plug wire and a plug, as these often break on removal. Keep 2qts of oil and beg your friends for 2-3 more. - Broken exhaust
Fix: Cut off part that is wrapped around the axle and setting things on fire. Need a good hacksaw with a new blade. - Electrical wiring (Connector or wire strap snapped/disintegrated from heat and age, burned insulation from exhaust contact, etc)
Fix: Electrical tape, zip ties, crimps/wire cutters/crimps, assorted spare wire, spare fuses. - Alternator/charging/battery problem:
Fix: Multimeter to determine charging system state, above items. - General fluid leaks
Fix: Radiator stop-leak, tube of RTV - Gas tank leak/puncture
Fix: Sheet-metal screws for pinholes, steel epoxy. Skid plates.
- All of the above happening at night
Fix: Headlamp and trouble light
Thanks!
John
