calicamper
Photos to be added soon.
I have the basic parts and have been fooling around with them since Saturday.
The heart of the system is a $27 solar controller for battery/solar street lights. It is a fully set up battery manager with voltage screen and various modes etc. It even has an out put up to 20Amps max which will shut off when the battery hits 11volts.
The use for this set up is very light power needs. So I have a 18ah 12volt battery thats a perfect fit in a 50mm ammo box. The solar controller/charger will be mounted in the box also as it has a temp management feature also. I bought a Renogy 10watt small solar panel. So far the quality of this stuff is impressive. Doing some load testing and solar panel testing I think this set up will handle our light power needs.
The little atv KAWELL LED flood draws 1amp. This will be mounted to the back of our trailer with a remote led key fob switch.
I have basic plans to add some small led strip lighting inside the tent draw will be pretty low 2 amps at the most. The big power draw will be a charging hub for gopro, cellphone etc.
Tonight Im going to test the 11volt shut off, then have it set up for solar charge the minute the sun comes up.
The little 10watt panel easily generates 15volts in full sun and can manage over 14volts in shaded location which is pretty damn good. So we'll see how it goes. If I need to add more solar capacity Ill get a second panel as these are small and can easily be packed up safe for rough roads etc.
