SOLD: Never Used 22" 2 Burner Partner Stove With Windscreen & BROG Bag
Never used located in Doylestown PA $400
PARTNER STEEL STOVE 22" 2 Burner Partner Stove With Windscreen
"This stove has the burners spaced 12" apart to more easily accommodate 10" pans. Additionally, the grill spacing has been reduced over the burner plates so that a small coffee cup can be warmed. The windscreen is a standard feature with this stove. 12 x 22 x 3 1/2, 17lbs. Stoves come with a hose + regulator set.
Made from high grade aluminum, and are built to last! The grills are Stainless Steel and the gas manifolds are Brass. Other than the burners, the entire stove is designed to remain rust-free and very low maintenance, providing years of service even in the most harsh environments. All stoves come with regulator and hoses."
Blue Ridge Overland Gear PARTNER STEEL STOVE 22" (2-BURNER) BAG
"Our Partner Steel Stove bag is the perfect way to store and transport your favorite 2-burner Partner Steel Stove. The bag is made of rugged 1000D nylon cordura and features all mil-spec zipper and hardware. A 3/16” layer of foam padding keeps your bag protected during transport. Mil-spec webbing carry handles are sewn to the bag for maximum durability and portability."
srockwood
