Sold - 2017 Conqueror 390, $10,000
Outside somewhere
Overland certified public figure brand ambassador
The what - 2017 Conqueror 390
Price - $11,500 with a brand new Alucab Shadow Awn, $10,000 without it.
The location - North Carolina
Condition - Used, but excellent
Title in hand
Only reason for selling is I am under a time crunch. My brother is a combat disabled veteran who recently relocated here, bought a small home and began renovating it for life in a power wheelchair with lower cabinets, wider doorways etc. He has started renovations and the govt grant he was told he was getting for some of the retrofits was canceled. Can always count on the VA to ******** things up. The grant was resubmitted but covid 19 has delayed everything for the foreseeable future.
Below you will find detailed specs from conqueror as well as notes on conditions of items, upgrades etc. This trailer has been meticulously maintained and stored in an ac'd/heated garage since day one. It's perfect for couples or growing families and the size makes it track great behind everything from a 4runner, wrangler, truck etc.
It is also a great platform for anyone with mobility issues. That is one of the reasons we purchased this type of trailer. The annex allowed my brother to cross in and out of the low threshold, fold up his travel wheelchair and transfer to a camping cot with zero assistance. The space of the annex allowed plenty of room for the ladder to still allow access to the top queen bed.
2017 Conqueror UEV 390
This is the base feature list -
-2500 kg (5500 pound) axle
-Gabriel shock with leaf springs
-Hot dip galvanized ladder chassis
-Electric 10″ brakes
-Off-road trailer hitch
-LED rear tail lights
-Adjustable Stabilizers, to stabilize unit when leveled
WHEELS AND TIRES
-Alloy wheels
-Dunlop at tires 245/70/16
EXTERIOR FEATURES
-Wood rack
-Jerry can holders and Military spec Jerry cans (Green)
-5 access doors and two access doors on Nose box
-Aluminum Stone Protection
-Aluminum ladder
-Conqueror canvas roof top tent with drop down room 2.4 x 2.4 m. PVC roof.
-L-shape PVC awning-Velcro and fitted on roof top tent
SLEEPING ARRANGEMENTS-BEDDING
-4+ Sleeper
-2.1m x 2.1m size bed
-High density foam mattress, covered in durable Conqueror branded covers
-Conqueror Branded Bed linen, fitted sheets, covers, pillow and pillow cases
KITCHEN-COOKING-STORAGE
-4 Wolf pack (plastic storage boxes) on sliders
-Storage clothing drawers on sliders
-Large mild steel powder coated nose box
-Steel camping table
-Rear outside wet storage boxes
-Dometic Stainless steel 2 burner stove
-Dual propane bottle holder and top strap
-Electroplated BBQ grid fitted on spare wheel
-Modular kitchen
-Cutlery drawer
-Fridge slider
-Crockery shelf
-Cutlery and crockery
-Refrigerator/freezer
-Grocery cupboard
-Pot holder
-Tent pole container with lid
-Bathroom/Vanity cupboard
WASHING UP
-Pop up shower cubicle
-Dometic Stainless steel taps / hot and cold
-Two plastic washing bins with bracket
-Pressurized water pump and plumbing (9L per minute)
-Movable shower rose and mixer tap
CONVENIENCES
-Mountings for axe and spade
-Axe and spade
-Eyelets for fastening of cargo to lashing rails
-Tie downs, 2 used to secure fridge
-Mosquito netting in windows
INTERIOR FEATURES
-Minibar bottle holder
-Utility bags
ELECTRICAL-POWER-LIGHTING-WATER
-Esperia level 2 Intelligent Power Management System
Set up for solar, 30 amp shore power etc
-6 x LED light fitted inside
-Hella Plugs x 5
-2x Battery boxes
-Anderson plug with 16mm wire connected to batteries for vehicle or solar charging
Items that have been upgraded or are new, recent replacements -
Both batteries are Northstar NSB-AGM31 group 31 Threaded Post 1150CCA, 220RC, 103AH ea.
The power pack system was upgraded by conqueror and has the ability to run lithium batteries, has an integrated solar controller and DC charger . It gives real time data on power, water etc
2000 watt magnum pure sine inverter
The mattress foam is new as of 6 months ago. Furniture grade from a company here in North Carolina that supplies foam to high end makers
The original Conqueror bedding has never been used (comforter, sheets, pillowcases)
All the bowls, dishes, glassware have never been used.
The optional on demand hot water heater is new as of 6 months ago
The pop up shower cubicle has never been used
The rear braai (grill) has never been used
The on board water tanks were dropped out and cleaned, cleansed at the beginning of October. I have taken great pains to keep it clean as this trailer is the only one in the US that has the on board water filter system. The system is currently dry but only needs to be flushed, run 2 gallons of Camco Taste Fresh (included) thru, use the TDS meter to check the quality and you now have fresh potable water.
All metal undercarriage parts have been coated with Fluid Film. If you don't know what that is look it up.
Our trailer was the first of the new style 390's to be imported. Just like the water filter system our trailer has the L shaped factory awning. Our also has the optional full enclosure kit for that awning.
Basically there are wall pieces that will enclose the entire area on the driver's side to the rear annex entrance. This means should you like camping in early spring or early winter and want your "kitchen side" enclosed for hanging out, cooking/eating you can do so.
However, we are people that like options so we decided that if we were just in one place for the night we want to utilize an awning system like the Alucab Shadow Awn. So I constructed a bracket out of aluminum extrusion that mounts on the driver's side of the trailer. It allows a Shadow awning to be mounted and open to fully cover from the pass side prep to cooking area. This is the only 390 in the US that has this. Other options add much more weight.
Again, I hate to sell this trailer. As you can tell from reading this ad from being garage kept in a heated/cooled garage year round, the upgrades, fluid filming the chassis etc we have truly cared for this trailer. The maintenance has been beyond anal retentive.
If this wasn't to give my brother a home that allows him to have the dignity of being 100% self sufficient we would keep this trailer forever.
Thanks for your time.
I'll attach more pics Sun, Mon.
Outside somewhere
Pictures
macro1
PM Sent.
You should be asking more for it and Im happy to give you more than you are asking!
Outside somewhere
I will be back home from work late in the day on Wed. I replied to some messages but not all as I was working, driving. If anyone wants specific pictures, info I will gladly get that to you. I just posted what was on my phone and some basic pics to show what it looks like. Someone messaged me re: the oem pictures. Not sure if that person felt this was a scam like I'm listing something that isn't ours. I assure you, it's ours. Anyone that has been to uwharrie events, appalachian round up, shamrock shakedown, expo east, mlo event, vor etc has seen us there. My wife found some pictures on her phone and I'm posting them below as well.
One person had asked about a fridge not being on the description list. There is no fridge on the trailer. It came with a national luna which was supposed to be a "top tier brand" but 10 months after we got it, it died under warranty. I was quoted almost what a nice new snowmaster, arb classic 2 would cost to fix it. I opted to just use our trusty 8 year old beat up arb fridge which is not included. I'd feel terrible if someone tried to use it and it died. Plus it looks like godzilla ate it and ******** it out. The original wiring for the on board fridge is 100 percent in tact. I sacrificed my arb cord and put an anderson end on it. The trailer came pre wired with a nice anderson plug connection for the fridge which is still there. No modifications have been made to anything electronic etc. Just wanted that said for full disclosure.
I will get back to those that have messaged me in the order they messaged to see if they are interested if not I'll contact the next person. I've never sold anything like this but I have been advised to accept a cashiers check for payment vs electronically transferred funds. Guess paypal, venmo etc have had some issues on larger sums?
Outside somewhere
Solarunner
