D
Deleted member 209877
Guest
This trailer has been used TWICE since purchased new from AT Overland Equipment in Prescott, AZ in 2012. It has been slept in a total of five nights and is, for all intents and purposes, brand new. It has always been stored indoors. See the Chaser Adventure Trailer review at https://expeditionportal.com/adventure-trailers-chaser-model-review/:
Chaser Trailer:
Asking Price:
$12,500 with wheels and tires
$11,750 without wheels and tires
Located in Prescott, AZ
Chaser Trailer:
- Powder Coat Color: White with black chassis & fenders
- Trailing Arm Suspension with Rancho adjustable shocks and air struts
- Cargo Box (46-ft3) with two gas assisted struts to assist lid opening
- Steel Powder Coated Nose Box (19-in tall x 16-in deep x 30-in rear/14.5-in front wide)
- Tail Gate: 16-in x 32-in with locking T-handle latches
- Drop Leg Jack, mounted on tongue
- Electric Braked Axle Upgrade with 10-in drums and break-away kit
- Max Coupler Multi-Axis Coupler, Class III rated at 6,000-Ibs
- Aero Silent Hitch Pin
- Rubber Matting in cargo area
- Cargo Tie Downs: 8
- Accessory Receiver: 2-in on rear of trailer
- Rear Stabilizer to prevent trailer movement when parked, never used
- Adventure Trailer Holder for two 5-gal fluid cans
- Two 5-gal Red Fuel Cans (never used)
- Two 5-gal Blue Water Cans (never used)
- Wheels: Two, American Expedition Vehicles (AEV), 17x8½, Argent color, Beadlock, with 5 on 4½-in bolt pattern
- Tires: Two, BFG Mud Terrain T/A KM2, 37x12.50R17LT
- Five storage bins
- Viking synthetic rope stability strap to steady a tipping trailer
- Model: Eezi-Awn Globe Drifter with integrated, self-supporting retractable awning
- Eezi-Awn Add-A-Room with four sidewalls, windows, bug mesh, door, & separate floor (never used)
- Color: Beige
- Bed: Queen (79-in x 63-in) with 3.3-inch thick mattress
- Pillows: Two NEMO Fillo inflatable pillows
- Ladder: Aluminum, to access sleeping area/bed
- Mount: Three load bars on adjustable track
- Battery: Marine/RV Intimidator deep cycle battery, valve regulated, AGM Group 31, 105 amp with tray & hold down
- NOCO Marine Charge On-Board 10-amp single battery charger & maintainer with shore plug
- Power Inverter: Fusion Power, 1,500 Watts
- 60-watt foldable Solar Panel with RV-20 controller, 15-ft extension cord, weather pack kit, RV plug male and female, installed in cargo box
- Auxiliary 12V power wiring with night lights
- Three fused outlets
- Floodlight: Maxima MWL-04, 4-in x 6-in rectangular HD floodlight with six LEDs
- Refrigerator/Freezer: National Luna Weekender, 50 Liter Stainless Steel with base plate and insulated protection jacket
- Water Tank: 19-gallon roto-mold with 1¼-inch opening, ½-inch drain plug, and hand pump
- Propane Bracket: COMP, 2 clamps, fits 9-in diameter/10-lb tank, mounted to trailer right hand side
- Propane Tank: Manchester, 10-lb vertical cylinder
- Sink: Deluxe stainless-steel with drain hose
- Hardwood Plywood Utility Shelf, with locater pins that mounts atop either fender (16.5-in deep x 43-in long x ¾-in thick)
Asking Price:
