SOLD - 2009 Jeep Wrangler JKU - Overland and Trail Ready, Well Equipped
Discojgb
Engine - 3.8l V-6
Transmission - Automatic
Miles – 166,000
Color – Deep Water Blue Metallic
Interior – Dark Slate
This Jeep Wrangler JK has been a great vehicle for our family and allowed us many adventures and has been extremely well cared for. The Jeep was built for trail use and as a display vehicle having been highlighted as a booth build for the SEMA show, Off-Road Expo, Easter Jeep Safari and Overland Expo West and many other regional events. Below I have listed some of the key modifications and maintenance that makes this Jeep stand out from the masses, with the most recent addition a new Bestop Supertop in Twill, Genesis Dual Battery System with Full Throttle Batteries and Cascadia 4x4 Hood Solar.
Exterior Features & Upgrades:
- Bestop Supertop Ultra Black Twill Soft Top
- ARB Front Bumper
- Warn Winch with Synthetic Line
- Factor 55 Fairlead
- Factor 55 Flat-Link
- ARB Rear Bumper
- Teraflex HD Rear Tire Carrier
- BOLT Lock J-Mount
- Hi-Lift Jack
- Icon Vehicle Dynamics Stage 3 – 4.5” Suspension lift with 2.5 remote reservoir shocks
- Energy Suspension Front Control Arm Bushings
- Icon Vehicle Dynamics adjustable pass-through steering stabilizer
- Icon Alloys Alpha Serie Wheels
- BFG KO2 AT Tires 37x12.5-17
- MOTIVE 5:13 Gears Front and Rear
- Ten Factory Chrome Moly Axles (Front and Rear)
- Eaton True Trac in Front
- RARE Parts Ball Joints
- RARE Parts Tie Rod and Drag Link
- Hellwig Suspension Products Front Adjustable Sway Bar & Quick Disconnect End Links
- Hellwig Suspension Products Rear Sway Bar
- BAER Brakes Front Big brake kit with 6 piston billet front calipers, slotted-drilled rotors and Russell stainless lines
- HAWK CP Performance Front Brake Pads
- BAER Brakes Rear big brake kit with 4 piston billet rear calipers, slotted-drilled rotors and extended stainless lines
- Artec Front Axle Truss kit, Lower Control Arm Skid Plates and C-Gussets
- Synergy Sector Shaft Brace
- Synergy Front Track Bar Brace
- Dana Manufacturing Front and Rear Differential Covers
- EVO Manufacturing Engine Oil Pan, Transmission Pan and Connector Skid System
- Poison Spider EVAP Canister Skid Plate
- Injen Intake and Snorkel
- MBRP High Clearance Stainless Steel Cat-Back Exhaust System
- ARB Single On-Board Air Compressor
- Bushwacker Rocker Trim
- Bushwacker Cowl Trim
- Rock Slide Engineering Next Gen Step Sliders
- Rock Slide Engineering Step Slider Skid Plates 3.0
- Drake Aluminum Hood Pins
- S-POD Bantam Switch System
- Oracle Oculus Colorshift LED headlights
- Oracle 8 pc Colorshift Rock Lights
- Flex-A-Lite Transmission Cooler and Electric Fan (Manually Controlled)
- Genesis Dual Battery System
- Full Throttle AGM Batteries x2
- Cascadia 4x4 Hood Solar System
Interior Features & Upgrades:
- Superchips Traildash 3 Tuner
- Vector Off-Road Mounting System
- BEDRUG full interior carpet kit
- Trailgater Tailgate Table
- PRP Seat covers Front and Rear
- Bestop Floor Liners
- Cobra 75 Series CB
- Midland GMRS 15 watt Radio
- GraBars front and rear
- Bestop Driver Side Under seat Lock Box
- Drake billet Fire Extinguisher Mount and ABC Fire Extinguisher
- ARB Fridge wiring kit (power port)
- XG Cargo Roll Bar Storage Bags
Notable Maintenance
- Red Line 5W20 Oil Changes – Mopar Filters
- Newer Champion Spark Plugs
- New NGK spark Plug Wires
- New Bosch oxygen Sensors
- New Timken front hub bearing assemblies
- F&R Differentials Serviced / New Fluid Red Line Heavy ShockProof
- Transfer Case Serviced / New Fluid Red Line Gear Oil
- New Dana/Spicer U-Joints (front axles)
- Have replacement coolant hoses and Red Line Supercool for Coolant System Service
Asking Price is $29,000.00 or Best Offer
Willing to Deliver on the West Coast, Motivate Seller
Discojgb
More Pics :)
Discojgb
More interior shots. All MagLites stay with the Jeep, any other questions please feel free to message or text, 360-314-7021
Discojgb
Great jeep and I hope it sells quickly for you (I already have 1 too many), what rear view mirror do you have?
Thank you! It is the Brandmotion FullView Mirror. It has forward and rear facing cameras with build in DVR (Micro SD Card Expanded) and shock sensor, great little system.
Discojgb
Wanted to go a little more in depth to some of the questions I got on the suspension.
System is an Icon Vehicle Dynamics 4.5" Stage 3 Suspension system, with their 2.5 Remote Res Shocks, Hellwig Suspension Products front and rear sway bars and Energy Suspension front control arm bushings. It has held up exceptionally well and would absolutely do it again! The load and handling has been phenomenal, especially with a 37" BFG!
Discojgb
The ball joints are by Rare Parts, it is their dual load carrying kit. They are by far the best ones I have had experience with. Here is the video that explains it better than I could. 100% worth it if you are looking to put a better part in your overloaded... I mean Overland Jeep ;-)
jgrillz94
