I have the Mantec raised air intake on my LR Discovery and it has the same noise, and it is located at the roofline. I think most will do this, I am not sure on the mushroom/pre-filter style ones though. That is if that is the reason why you would get one with the intake raised higher.It works as it is designed to (well... it's a bent plastic tube) but should I do it again, I would buy one with the intake in line or slightly higher than the roof.
When I drive with the passenger side window open, I get a bit of engine growling and sucking noise from the inlet.
That was a unwanted side effect.
Ahh OK. So it sounds like the increased engine noise comes with adding any snorkel.I have the Mantec raised air intake on my LR Discovery and it has the same noise, and it is located at the roofline. I think most will do this, I am not sure on the mushroom/pre-filter style ones though. That is if that is the reason why you would get one with the intake raised higher.
WOW :wings: , Thanks for the link !!!I just spend a little time looking thru the german forums and found this thread.
http://www.viermalvier.de/ubb_portal/ubbthreads.php/topics/371116/1
The various G pictures don't need any translating![]()
