Wyowanderer
I'm rewiring the camper to get rid of the mess that the factory invented. From the aux. battery to the camper, I'm going to run a couple 6g cables With a Mega Fuse holder close to the battery and I need to know what best practice is. I had considered using 6g wire from a set of battery cables-what do you think? I'm a little concerned about the quality of the insulation, so I'm not so sure.
My other option is to run some 6g cable (bought from NAPA or similar), but I don't know if I can run both in the same loom or if I need to loom them separately.
Inside the camper I intend to use 14 and 12 gauge wire to power the fridge, furnace, and CPAP, after terminating the wire at a Blue Sea fuse box. I'll also add some lighting, probably decent quality fixtures for RV's, adding LED conversions to them.
I'm also going to add three or four Blue Sea 12V cigar plugs and an Engel fridge plug to the sleeping platform for the CPAP, phone charging, etc.
I'd appreciate any ideas and guidance.
Thanks.
Thanks.
