I wonder how long those laptop security cables are...hmm....I think I just came up with the killer solution...
PVC pipe - cut a slot in it on one side with a dado blade - make a little longer than the width of the panel. Drill holes in line with the grommets, using security hardware, fasten the panel to the PVC pipe.
here's the catalyst. It just occurred to me that cutting the area where the grommet is would still leave the panel useful if someone liked it more than I.
So, by covering the grommets and the area that could be destroyed and keep the panel useful, you make it less attractive for the smart thief because he'll probably recognize he's gonna damage it and make it useless.
with the PVC pipe longer, you can also put eye-bolts or something like that out at the ends.
Do this on both ends and you can keep the panel flat and attach it anywhere you want.
Also, on Corey's pic - he's lined up with that tree where there's a fair bit of sun shining on it - I wonder how you might attach the bottom of the panel to the top of the tent, and get the top of the panel up to th tree where there's even more sun to "work with"...
Ahhh...imagine a hammock - this is what I'm thinking you'd end up with for fastening the panel.. so, you'd have triangles on each end. With a telescoping pole of some sort, you could reach the top of it fairly high I'd think..??
So, youandi - put the PVC poles on each end, and fasten those to your rack, then fasten the panel to the PVC pole..
In my mind, if the PVC pole even covers the actual solar part a little, that would be even better, maybe take a file or something and round off the edge that's close to that to prevent premature wear..
