(RESOLVED!) Rhino Rack Awning bracket hardware??? ISO...
JCS2179
Hey folks, does anybody know where can I get a couple of these little sorta "T"-Bolt/screw thinghys with a nut?? It shouldve come with the brackets for a RR Compact Awning, but it didnt.
Anyway, if you know or you have a couple, I'll grab them please.
Let me know.
Thank you,
JCS
Cayenne
Just buy a channel nut and matching bolt. Ace hardware or Grainger will have what you need.
https://www.homedepot.com/p/Superst...nel-Spring-Nut-5-Pack-ZA1003-8EG-10/100179881 You can remove the spring
alia176
These strut channel nuts aren't going to fit the channel in a typical awning extrusion channel. Secondly, he is wanting a Tee bolt, not any kind of a nut. Amazon has Tee bolts, made for wood projects but may work in this application if you can't live with a simple hex head bolt.
JCS2179
So to close this thread out, in the end, I went to ACE Hardware and bought (2) M6 x 1" HEX bolts. I shaved one side of the head down and it fits perfectly onto the Rhino Rack BW awning slots. It's a solid fit. $2. Done.
WonaWarrior
