brad2274
so ive known my body mounts in the front since i got the truck a few weeks ago, but alignment shop said the same plus one of the bolts is bent. tried pulling front mounts out of a 96 ls (i have a 95ls) in a upullpay but couldnt get them out after removing nuts and much wedging. they had a few cracks anyways so i gave up.
i cant find these anywhere online, ive searched everywhere, cant find how to remove them in the FSM either, any help would be great. may consider body lift if that could be an alternative to replacements
heres pictures of the 2 when i jacked it
(edit) i just noticed something, i remember removing large washers between the nut and bushing below the cup on the junkyard 96 mounts, i dont see any washers on mine and that could be the reason mine are trashed. assuming the 95 is the same as 96 with mounts. this has a replaced fender and the front end isnt all on right(missing grill mount and piece below lights is replaced and looking bent) but the frame is straight(had it checked) so im wondering if someone forgot them when it was apart.
