Quiglys van lift
There is a lot more than just adding springs and shocks.
I have been working on a 6"suspension lift on my van. I tried to only use springs and shocks. To get the ride we all are looking for here is what it takes.
Rear add a leaf,longer shocks valving is based on your van weight,front new spings, longer shocks, new lower control arm mount ( shock mount) 36" lower control arms, 27" upper control arms, new longer adjustable track bar and relocating mounts, new frame control arm mounts, new trans support for front driver shaft clearance, new front sway bar,. With all this you get the handling and ride control. That we all should have when we pick are quiglys up from quiglys .
Mine is is running on 35" tires, and loaded,and pulling my rock buggy.
I all most sold my van after driving it. But after reading about all the quiglys van owners complaining about ride and driving control I set out to solve this problem. And I have done that. And for those that want a bigger tire (problem is solved). And for those that like the factory ride height .I'm working on the front springs and the right valving shocks. The biggest problem I see is having to figure out the different valving for the different weight of the vans.
We are really close in rolling out the up grade lift kits.
I would not sell my van now for any amount of money.
