Borrego60
Rendezvous Conspiracy
I was out in Borrego the other week and had a flat tire on the left front. OK no big deal, broke out the bottle jack got it under the truck and the jack was to high, so I dug a hole about 3" deep lifted up the A arm and took off the tire. good to go so I thought, went to put on the spare and had to dig another hole so the spare would fit. This is not going to happen again. So now I carry a 2ton floor jack made out of aluminum and a mount with a quick release. I also had to remount the high lift jack and remount my pull pal. This is what I came up with. I used T handle pit pins to mount the Pull Pal,and the spade fits nice and tight behind that. The Handle for the floor jack has a spring mount on one end and a cup on the other, just push the handle against the spring and it will come out of the cup. The floor jack has a quick release spring loaded pin for release of the jack. The floor jack is only 3" high. and will go up to 18". Here are a couple of pictures.
