Price drop! Sprinter - 4x4 - Heated Floors -Upgraded Suspension - 7.2k miles
jonchez
I had this Van professionally built to go head out on a Pan American trip this fall. Due to Covid some things have changed in my life and I am force to sell. I chose to have this built after looking at many poor quality and bloated builds.
The van is built for 4 seasons with extra insulation, hot water showers and heated floors to keep you warm in cold winters.
This van has a sound system, and comes with only 7200 miles and a 7 year warranty. Every aspect of this van was carefully selected for weight, durability and functionality. With all water and fuel tanks filled this fully equipped van weighs only 7540 lbs.
This link is to the original ad: https://www.ipacket.info/6F90464D-C886-8820-36440C3CDE397083
Link to sales page: https://vanlifetrader.com/listing/2...ear-warranty-upgraded-suspension-7-2-k-miles/
Link to album: https://drive.google.com/drive/folders/1h0nZarYRTdPiHsI7PV53t0yiejYjEdj6?usp=sharing
Heating and Floors:
  • Van Life Tech
    • Radiant heated floor system
    • 12,000 BTU Aux diesel heater with high altitude kit
    • Domestic hot water
    • Recirculating shower ready for when VLT launches their shower pan
    • Programable controller with ability to be controlled remotely
  • Lonseal Flooring
  • Aluminum trim
Interior:
  • Alpine mechanism low profile swivel seats
  • RB headliner
  • RB Rear door bags
  • RB sliding door panel
  • Adwag Mule bags
  • Adwag Ltrack kit
  • Finished in Bamboo plywood
  • Custom Tig welded and powder coated frame
    • allows for easy troubleshooting, maintenance, and visualizing quality of work
  • Latex mattress wrapped in tweet fabric for easy cleaning
  • 2 panel bed system that be removed to allow for hallway.
    • Lagun table can be attached to one to use as table.
  • Upholstered headliner and matching
Water system:
  • Water faucet -
    • motion sensing
  • Deep stainless sink
    • Hot and cold water at kitchen sink
  • 20 gallon tank -over wheel well
    • Stainless steel sensor
  • 30 gallon - Spare tire location
    • custom skid plate
  • 9 gallon Agile Offroad aluminum tank -
    • with stainless sensor
    • Motorized ball valve that can be open while driving
  • Water filter + UV filter - Ability to collect from any stream or river with additional pump.
  • 2 Water pumps with accumulator and silencing kit
  • Shower and water mixer
Kitchen:
  • Origo 3000 - Alcohol stove and oven - Stove can be used inside or outside
  • Isotherm 130 fridge
  • Dometic CF25 fridge/freezer - with insulated cover
Electronics:
  • Nations alternator 2nd alternator
    • Balmar charge regulator and temp sensor set up for lithium
    • Secondary belt kit- Not comprising reliability of vehicle- if this alternator fails you can still get out of where ever you are.
  • Solaria XT 360 Solar Panel -
    • Used to top off battery since alternator has protection mechanism that stops just before battery is fully charged.
    • Hein brackets on factory rails.
  • Cotek SC 2000 Inverter
  • Lithionics 400 amp Battery with internal BMS
    • Made in the USA, also used for military applications, in my opinion the best lithium battery you can buy.
    • Comes with the ability to trigger the turning on of vehicle and or generator at a certain discharge and its monitor.
  • 30 amp charge controller
  • Mid City Engineering -Remote start + Alarm + High Idle kit
    • This allows GPS tracking of vehicle, ability to turn on/ off, lock/unlock and other features from your phone using DroneMobile.
    • also has the ability to integrate a thermometer to view from your phone for those with pets
    • High idle is installed and just need to be programed- this was installed in case I added and air conditioner to the van.
  • Top of the line peripherals
  • Dimmable LED lights that can be controlled from multiple places
  • 110v outlets throughout
  • 12v charge ports throughout
  • Maxxair roof vents, rain-proof, remote controlled
  • 220v Shore power hook up
  • Simarine monitoring system
Audio
  • Pioneer 7 inch touch screen Radio with apple Car play and android auto.
  • Rockford Fosgate 6.5 separates in the front
  • Rockford fosgate 6.5 in rear doors
  • Rockford Fosgate 300 watt 8 inch sub under passenger seat
Insulation + Sound Deadening:
  • Lizzard skin paint
  • Thinsulate kit from ADWAG
  • Hushmat on all wall panels and Noico on floor and wheel wells
  • Upholstered paneling
Suspension and Wheels:
  • Van Compass Stage 6 Lift - Matched to loaded Weight
    • Front 2.0” strut spacer - 1/4” hot rolled steel
    • Front 2.0” subframe drop spacers - 4140 heat treated chromoly
    • Motor mount 2.0” lift spacer - 3/16" hot rolled steel
    • Transmission 2.0" lift spacer - 3/16" hot rolled steel
    • Steering shaft extension - 4140 heat treated chromoly
    • Low pressure power steering hose extension
    • Front brake line relocation brackets
    • Rear 5 leaf mini spring pack
    • Rear sway bar links - 11/16" x .120 DOM and 3/16" hot rolled steel
    • Rear lower shock mounts - 1/8" hot rolled steel
    • Rear bump stop drop brackets - 1/8" hot rolled steel
    • Rear ride height headlight adjustment extension bracket - 1/8" hot rolled steel
    • All necessary hardware
    • Front Fox shocks and mounting brackets
    • Front Sumo Springs
    • Rear Fox Reservoir shocks with compression damping (CD) adjuster
  • New BFG KM3 285/75/16 x 5
Other:
  • 7yr/ 175,000 Miles Warranty from MB
  • 3yr/ 36,000 Miles warranty on all work done from Builder
  • Amp Research Step
  • Noco Lithium jump starter
  • Lagune table - not installed
  • Spare tire carrier
  • Tinted windows
  • Delivery options available
PRICE: $ 129,00,000
Thank you for your time!
geovangelist
Can you share what changes you made to this van to be able to run on the diesel fuel that is available for much of the Pan American Highway? I have narrowed my search to gasoline powered vans bc of the unavailability of low sulphur diesel south of Mexico, but I know some folks modify their post-2006 Sprinters to be able to burn whatever diesel is locally available. Thanks. Cool build and GLWTS!
4x4tripping
A very beautiful setup!
Guess above the 3.5 tons we in Europe has usually in the driving licence? // Edit: 3420.086kg - reread the entry post-..
Surfy
supermoo
Interested to understand how you did the radiant heat floors. The. floors in the winter have to be the. worst insulation point of most vans. Able to use the van in real. winters?
jgrillz94
