Pre-emptive commentary: I will be building a better full-time electrical setup into our Super Pacific once it is ready but for now I'm trying to deal with an assembly of random parts to meet some short term needs.
All components discussed in this thread are linked below the narrative.
I'm thinking through my plan for maintaining power for our family during a week long trip later this year to some national parks. Our primary power needs are a CPAP machine and an ARB fridge. The campgrounds at which we are staying do not have shore power connections. Our Power Wagon has a 400 watt power outlet in the truck bed. While driving, my plan is to plug both the Goal Zero and the Schumacher automotive battery charger (connected to the Group 31) into a power strip that is plugged into the 400W outlet to maintain charge in both batteries. The fridge is then connected into the Group 31 battery using an ARB style plug. When we stop, the battery will power the fridge and while driving, the charger will charge the battery. The Goal Zero gets used exclusively for the CPAP machine at night. I've generally found that I can really only get 2 nights, maybe 3 out of the GZ for the CPAP, so I don't connect the fridge into it. I've also found that the fridge can run 3-4 days (maybe more, but haven't tested) running off the Group 31 battery without a charge.
During this trip, we'll be exploring national parks (Yellowstone/Grand Teton) during the day, so the truck will get driven and thus the bed outlet will prove helpful. I also have solar panels that can be leveraged, if it makes sense to do so. The panels can either be connected directly to the Goal Zero, which has a built in solar controller, or through a simple Renogy Solar Controller and then connected to the Group 31. The panels are not attached to the truck, so would largely only see use at the campground, assuming there is any decent sun.
My questions:
Batteries
Goal Zero Yeti 400 with 35Ah replacement Duracell battery (originally 33Ah)
Duracell Group 31 Deep Cycle 105Ah lead acid battery
Solar Power
2x Renogy 100 Watt 12 Volt Monocrystalline Solar Panels
Renogy Wanderer Li 30A PWM Charge Controller Edit on 8/3: Victron Energy SmartSolar MPPT 100V 30 amp (changed the system to allow for future growth and a more sophisticated controller)
Power Needs
ARB 50 Quart Classic Series I Fridge
CPAP Machine
Shore Power Charger
Schumacher SC1280 15A Rapid Charger
My questions:
- Any reason that I shouldn't use the power strip in the bed outlet, assuming we stay below 400W?
- Any reason that I shouldn't use the Schumacher 15A automative charger to charge the Group 31 battery while on the move? (Edit: it has a 3A output setting in addition to the 15A rapid charge.)
- Does the 400W outlet seem sufficient that we wouldn't necessarily need the solar panels?
- Drive time to Teton is 8 hours (probably 10 with stops)
- Drive time from Teton to Yellowstone campground with stop is about 3 hours, maybe more with stops
- Projecting 1-2 hours of driving each day while at parks, just to be out exploring
- What am I missing?
Batteries
Solar Power
Power Needs
CPAP Machine
Shore Power Charger
