i was thinking about buying a cheaper tent or the material and just hand stitching the entire panel in... i can usually figure stuff out. i also noticed the driver side latch on the lid portion is pulling out of the fiberglass..... need to look into pulling it off re fiberglassing that portion and re drilling into it or accessing it from the inside by cutting a small hole out and mouting it using bolts and nuts and then re patching the inside with fiberglass.Looks great.... I had some small cuts in mine, not enough to worry about for now, but I've been contemplating the same issue... pretty big job to remove this tent for repair... not sure how to handle it??!
