8 foot non-cab over 1960s Mitchel fishing hut slide in made in CO. I have sealed the camper and re-painted the inside. new roof vent, curtains and curtain rods also. The camper fits short or long bed trucks and works well on 1/2 tons. I also designed and built a hydraulic lift for it, 4 hyd. cylinders, legs and brackets connected to a hand pump. it will lift the camper so that you can back under it very easily. sleeps 2 comfortably, propane stove works great. sink but water tank removed and will go with camper. floor is insulated and has new plywood. also, the underside has new paint.
120 watts of solar power with charge controller, battery, and fuse block. 2 12v outlets and 2 12v lights. I was running a 12v fridge and could go forever without hooking up the truck to charge the battery. tail lights, clearance lights and 7 blade rv type plug.
1000 obo. listed on craigs list for 1200. I would consider knocking off some more if I can remove the solar setup. I will leave the fuse block and wiring. we have used this around 40 nights in the last 2 years and we are wanting something a bit bigger. the hydraulic system works pretty well.
e-mail is best or call 61 6-250-0 7 6 0
