Overland Explorer
Supporting Sponsor
- All Composite Pop-Up truck camper
- Designed for mid and full-size 1/2 ton trucks
- 1350 lbs
- $25,000 USD fob Red Deer, Alberta
- (detailed specs follow pics)
(pics below are first prototype, production model will vary slightly)
See you at OE West!
- Composite construction, hybrid panel with honeycomb skins and foam core, aluminum
- extrusions with minimal thermal transfer zones
- Raised and sloped roof with roof rack tracks installed
- High gloss gel coat fiberglass exterior and woven interior finish
- 6’4” interior height
- High load capacity locking roof supports
- Fully insulated soft sides
- Structural powder coated aluminum interior cabinetry
- Quick release integral aluminum jack brackets and 4 corner mechanical jacks
- Extend a bed platform for NS King size sleeping in overhead
- Spacious L shaped dinette
- Lagun table leg for multi position table
- Sunbrella canvas covered foam seat and mattress cushions
- Screen door
- Aluminum propane cabinet with 20 lb. marine horizontal cylinder
- Quick attach valve and hose for cook top
- SMEV stainless sink with flush mount glass top
- 20 gallon water capacity with 12 volt pump
- 12 volt group 27 AGM battery in sealed and externally vented battery box
- Truma Eco hot water and forced air heating system
- Bullfinch outside shower
- 12 volt outlets at refrigerator tray and counter
- LED interior lighting
- LED exterior lighting
- Pre wired for solar
- Fantastic roof fan
- Fire extinguisher
- Propane and carbon monoxide detector
- Smoke detector
- Seitz side window
- Emergency exit
- Truck specific tie down kit
We used a lot of experience in the design of this camper, we also used the experience of a lot of owners and travelers using similar products, and we feel the result is a near perfect marriage of real world function and manufacturing technology. We designed the CAMP to use a portable fridge, along with a portable cook top. Why hard mount these everyday use items, and then take up more space and weight hauling a couple of portable pieces of kit to use outside? Let’s just take the inside out instead. The horizontally mounted 20 pound propane tank provides the convenience of volume with reduced handling. Efficient Truma Eco forced air and hot water heating combined into a single unit reduce weight, and the space savings equate to more storage space for your gear. Quick release jacks make removal and installation quite literally a snap, no tools required.
