NEW Expedition Vehicle - Mercedes Benz Vario 814D 4X4
rask
Opportunity …
A first owner Mercedes Vario 814d with 35,000 km.
A unique world travel vehicle for 2-4 people. Suitable for a family.
2021 Interior (NEW)
Save the costs of shipping, the car is already in Central America fully equipped for traveling.
Chassis
Mercedes Benz Vario 814d 2001
Integrated space
-Wheel base 4250 mm
-Engine OM904LA, 4249 Euro 3
-ZF 5-speed manual transmission
-Transfer gearbox with off-road reduction
-Selectable rear-wheel drive
-All-wheel drive with central differential lock
-Differential lock in rear axle
-Parabolic leaf springs
-Drum brakes with ABS
-Tires Pirelli 285/70 R 19.5 tubeless
-1 Spare wheel with wheel lifting system
-Protective cover for spare wheel
-2 Fuel tanks capacity: 200 liters diesel (main tank 70 liter, second tank 130 liter)
-Auxiliary fuel pump for refueling allows refueling while driving
-Aluminium's roof rack
-Ladder to the roof rack
-8 Xenon high-beam headlamp 4 at the front and the rear of the roof rack and 4 at the front and the rear of the vehicle.
-Lights mounted sideways on the roof rack
-Trailer coupling
Interior
-2 air-suspended seats,
-2 rear seats with seat belts tested and approved for safety.
-2 Air conditioners: 1- Original, 2- Military high standard unit (provides 30,000 btu)
-Rearview camera
-KENWOOD radio with MP3/USB connection and voice control and Apple Car Play/Android Auto
-Marine compass
-Weather station
-GPS integrated system with Apple Car Play/Android Auto
Exterior dimensions
Length 7210mm , width 2200 , height 3200mm
Inner dimensions of the cabin
Length 5500 mm width 2000 mm , Height 1950 mm
Body unit construction
-Made by Twiga Travel Cars, (brand new, only 5 months in use) , sandwich plate panels covered by fiberglass composite
-Wall thickness 40 mm with polyurethane foam insulation,
-Bottom layer : 4mm noise reduction layer with vinyl cover above.
-Access to driver cab - The drivers cab is in the same space
Entrance door
-Entrance door is on the side of the car
-Aluminium folding step, two rear doors at the back. (all doors with double sealing rubbers for dust prevention.
Windows
Domatic scratch-resistant, burglar-proof hinged windows
With stainless steel frames
Double insulated thermal window glass
Blinds with sun protection and mosquito net
Roof vent
Scratch-resistant, burglar-proof boat roof hatch with Fiamma vent and mosquito net in the main room,
2 solar marine vents in the shower and above the bunk beds
Interior layout
Seating area for 4 persons.
Bunks
Queen size bed with electric lift attached to the ceiling , Size: 1400 mm x 2000 mm
Two bunk beds on the rear of the car 70mm x 1850mm when not in use can provide as storage space.
Sanitary room
-Shower and toilet room with door to isolate from living area, hotty potty toilet in the shower. The shower space is heated.
-Also useable as dry storage, with shelves.
-Outside shower with cold and hot water.
Kitchen
Countertop with integrated stainless steel sink
-LPG 2-flame stove
LPG Dometic oven under the sink
-Fridge with freezer, 140 liters Dometic CRX 140 in the kitchen
-Cooling box Dometic CFX 60L at the side door
- Base cabinets with drawers on ball-bearing full extensions
Shock-proof separation for tableware and dishes
Kitchen wall cabinets
Storage
Large drawers and cabinets on the sides and
Outside storage compartments
Stainless steel exterior storage boxes on the side and the rear
Workmanship
All furniture was built to the highest cabinetmaking standard
Made of wood core plywood with white surfaces
Heavy duty locks and hinges
Surfaces white with teak edges
Power management
Victron Multiplus management provides :5V, 12V, 24V,110V, 230V.
Control panel for power management and monitoring of liquid levels
Safety cutout, fault current breaker, battery main switch
Own, independent power supply for the body by 2 AGM batteries, capacity 24 V
Charged by vehicle’s alternator with charge distributor
Power supply through inverter 230 V AC, continuous output peak output 3 kW
-Solar system 2 x 300W with MPPT solar regulators (2012)
International battery charger, 90-260 V (45-65 Hz)
-Power plugs for usb 5V, 12 V, 24 V DC 110 AC, 230 V AC
-Shore power socket for external charging.
Lighting
Led lights over the table, kitchen, beds, and shower
Reading lights at each bed, seating area, above driver and passengers.
Lights for outside storage compartment
Fresh water system
Tank volume 320 liters freeze-proof fresh water tanks,
located inside the body
All water installations are laid frost-proof in the heated indoor area
-16 liter hot water heat exchanger with electric heater
-Outside shower
Drinking water filter with tap on the sink in the bathroom
-Wastewater tank, capacity 20 liters, freeze-proofed
Toilet system portable Hotty Potty
Heating system
Webasto air top 2000 central heating (5 kW) for diesel operation with 10 nozzles all over the vehicle.
Air conditioning
Manufacturer A/C
Military standard unit provides 30,000 btu on the roof.
LPG supply
-LPG 2-flame stove
-LPG oven under the sink
2 x 5 kg LPG bottles
External LPG connector on the outside of the vehicle for cooking with folding element for stove.
Music system
Kenwood integrated system with Dab antenna, MP3/iPod connection and voice control
Speakers by the driving and seating area
Others
-Awning (Fiamma s-40) 4000 mm width x 3000 mm length
-Air pressure service points on both sides of the vehicle
-Tools and spare parts for service including fuel pump, vehicle computer, and diagnostic cables.
-2 portable Motorola radios
USB charging ports all over the vehicle
Body
-Shore power cable 50 amp
General information
-Weight 7500 kg
General condition very good like new
Licensed: UK
Mileage: approx. 35,000 km
Price
-Asking price 250,000 USD
-UK registration
-Vehicle location Central America
Contact: guyras@gmail.com
Furaites
Awesome looking rig, in a good place to get started (if your country will let you leave). Good luck with sale, just out of my universe for price
adam88
Nice vehicle but this can't legally be imported into the USA for 25 years, or Canada for 15 years. Too bad.
bartheil
Compared with a decked out Sprinter van... (which are also lots of money) I would choose this one for a family of four.
Unfortunately , both are out of my league and the only thing I could afford was a 2018 Chevy trailblazer...
