My 4x4 Red Cross ERV Build and Adventures
Rebuilder
Builder of Things That Interest Me
Hey Rebuild what are you using to cut the aluminum inside the cab- things like the diamond plate? Grinder? Plasma? Saws all?
I used a plasma cutter and a reciprocating saw. It was a little sketchy with all the sparks but it worked pretty well.
Bikersmurf
I’ve found the ultra thin cutting discs on a die (or angle) grinder work very well. They are what a older locksmith I know recommend for cutting $$$$$ aluminum doors. When installing electronic locks into aluminum doors there’s no margin for error.
Rebuilder
Here's the current state of the shower/toilet. I went around and around on what to use for the walls and ended up just using the same waterproof flooring because why not. I still need to finish the ceiling and add a cover piece over the wires but I really like the way it turned out. The shower valve and head are actually a bidet set that I found on Amazon. I originally bought an "RV" set but it was junk and I couldn't find anything else I liked so I found this and it ended up working great.... and it's great for showering too!
Oops a little blurry but here's the Nautilus retractable door. It's not as wrinkly as it looks.
The start of the kitchen.....
I like grey.
Well this is pretty much where it's at right now. Next I plan on continuing on with more cabinets, one to enclose the electrical/water heater area and one for clothes that will be located over the batteries on the passenger side.
carnut1969
I’m thinking that for my shower which will be very similar I’ll use a max air 6” dome vent with the built in led light. I think it would be good to vent all that moisture out of the van....
Rebuilder
Yeah the domed vent or even a skylight would have been nice for headroom in mine. I left a gap at the top of the shower door so I think my vent will do enough but the headroom would have been nice.... luckily I'm kinda short.
Rebuilder
any updates?
Not really on the build but I did take it on a 3000 mile road trip this summer. Minnesota to Steamboat to Ouray to Durango to Taos to Oklahoma City to Bentonville AR and back to Minnesota. It was a great test for all the systems and pretty much everything worked as it should with a few exceptions. The bed lift was great because I spent most of the time hanging out on the back deck. The shower was amazing. The solar and batteries work as they should. The Induction cook top worked great but I think I'm asking a little much for them with microwave/convection oven. The hydronic diesel heater and calorifier worked great for hot water but I didn't really test the in floor heat. It's parked for the winter now but I hope to get it finished up in the spring.
Wildfire smoke in Steamboat
Best free camping spot ever
Ouray...
Another great free spot in Durango
On the way to Taos
Free camping in Taos Ski Valley lot
Abitibi
I like grey.
Great turn out, custom builds are the best! I'm also looking at a shower valve, had the same idea to use a bidet one but couldn't figure if you can adjust the temperature or not with them?
Cheers
David
Sent from my SM-G973W using Tapatalk
Rebuilder
Cheers
David
Yeah the bidet works great.... works great as a shower too :cool:. If I had one #firstworldproblem with it I'd say it has too narrow of a spray and is almost too much pressure. The one I got is temp adjustable and has an On Off button on the head so you can leave the temp where it's at and turn the head on and off as needed.
https://www.amazon.com/gp/product/B07CMX71JQ/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
Not sure if the link will work so you can also search
TRUSTMI Toilet Concealed Hot and Cold Bidet Spray Set,Brushed Nickel
Abitibi
Perfect, thanks! The one I looked at was different, yours might work better. I'm also planning an outdoor shower and would use one for that purpose as well.
Cheers!
Rebuilder
Cheers!
I installed one of these for outdoor use and really like it. The coiled hose is nice to extend out for cleaning bikes and motorcycles...
carnut1969
Looks like a great trip!
After living with the truck anything you’d do differently? Do you feel the side door is worth the space cost?
I was thinking I’d just use the back doors and install one of those flip-down RV step systems.
My wet bath will be where your side entry is, then the area in the back can be used for a couch/ bed plus room for a bike or two....
WonaWarrior
