My 2014 Tundra Double Cab TRD 4x4 Camping Rig Build Write up and Pics!
RAM5500 CAMPERTHING
OG Portal Member #183
Hey Guys
It's been a LONGGG time since i built up a rig, but i am really enjoying this build. I do a lot of dirtbike riding/racing, and got tired of towing around and dealing with my toy hauler. Sold the toyhauler, and decided i was going to just build up my truck to serve the same purpose. Did a few months of research, and came up with what i feel is the ideal plan for this build, and i will try to explain why.
This build is a bit different then most. Even back in the day, when i built up a rig i always used the same, keep it as simple as possible. The less moving parts the better. I've done the whole roof top tent thing, it was "cool" but i never really dug the idea of that much weight messing up the center of gravity, and the 3-4mpg it eats up. Anyway, here is my build, not quite done, but getting there..
DONE:
STILL TO DO:
  • Suspension: Still undecided but leaning towards Old Man Emu
  • Clean up the wiring
  • Finish passenger side of fridge platform for storage
  • Line-X or similar coat the wood
The truck started out as a 2014 TRD SR5 4x4 Double Cab, bought new. First thing i did was swap out all of the chrome to the matte black OEM pieces that come on the base model.
11054297_800983273329061_1645417156837978365_n.jpg 11013362_800983663329022_7800660773376784268_n.jpg
Since i very rarely have more than one person with me, and the truck is always filled with camping or dirt bike gear, i removed alll the rear seating, and designed a platform for the fridge, inverter, AUX battery, and fuse block
11219139_894413783986009_7592182066120689255_n.jpg 12039467_894940707266650_8664274222304554090_n.jpg
I went through several iterations of how i wanted everything layed out and wear, and decided the battery would be in the center of the platform, mounted with an Artec Industries mount.
I went with the Odyssey PC2150 for the biggest deep cycle readily available. I mounted the Artect mount using flush stainless allen heads with barbed insert nuts underneath,
11999018_895451473882240_761688691568323981_n.jpg 12047025_895451537215567_6136365394809307227_n.jpg 12049300_895816277179093_3437873924414869409_n.jpg12019788_897029493724438_2471985151506002940_n.jpg
For the dual battery system, i chose to use a Power Gate Perfect Switch Dual Rectifier Isolator.. I have used them in 3 other previous builds and they have performed flawlessly under the harshest conditions, and are made locally!
I mounted the Isolator under the hood in the engine compartment on the passenger side, close to firewall, and wired it all with marine grade custom cables.
12033122_895452647215456_6729041758871066905_n.jpg12038553_896535833773804_4097478546293115061_n.jpg
RAM5500 CAMPERTHING
For the inverter, i chose the Xantrex 2000 watt ProSine. It will power everything i need, and their legendary reliability is second to none. I mounted this as close to the battery as possible with the biggest cable possible to minimize voltage drop. I also installed a Blue Seas fuse block. I also rewired all of the OEM 12v outlets to be hot and run off of the AUX battery and installed a 12v and dual USB plug in the center console that always hot and tied into the Aux
12108036_902069033220484_2491513507282849064_n.jpg 12143092_902375959856458_4179264290379380296_n.jpg 12118827_902069043220483_7207949269856532010_n.jpg
The wiring isn't 100% done and finished yet, and will definitely be cleaned up a lot!
12049230_898225226938198_5280484947251362685_n.jpg 12122849_902469039847150_6835586555351835987_n.jpg 12079127_902469066513814_6946532469642980839_n.jpg 12109279_902469079847146_6572207355162025110_n.jpg
For the fridge, i really looked hard at all my options.. I have run the ARB, the Norcold, and an Engel back when I used to do this years ago, and had great luck with all of them. What i couldn't grasp is how much the price has gone up on ALL of them! The MT45 was $689 for years and years, and now its damn near a grand. I'm not holding anything back on this build, and i really don't have a budget limit, but I simply couldn't justify that much $ on a fridge.
After doing a lot of research, the Edgestar 60qt seemed to get rave reviews, and the dimensions fit my project PERFECTLY right behind the drivers seat.
The fridge is mounted on the drivers side, right behind the seat, and the way it is designed works perfectly, and does not need one of those very overpriced slide outs. Easy access.
12033157_894413810652673_6854165699834237569_n.jpg 12032618_898437910250263_3510858329302596914_o.jpg 12033082_898437956916925_2993244934328267467_n.jpg
RAM5500 CAMPERTHING
One of the main purposes of this build and selling of my toy hauler was a place to sleep comfortably. The plan is to use the bed as a sleeping platform.
Again, i was blown away by the cost of the "expedition" drawer systems, and did not see a single one that went over the wheel wells to make one big sleeping platform.
While looking at options, i came across the "Decked" system. Found a shop locally that sold them and went and checked them out. A customer of theirs had one in their truck, and it was EXACTLY what i wanted/needed!
The price was almost 1/3 of what is currently out their, and its every bit at strong and functional! Very amazing product! Very simple to install as well!
12036770_900791466681574_6211945781729436865_n.jpg 12065992_900791503348237_6881312765637415598_n.jpg
After installing the decked system, it was time for a camper shell. I looked at all of them, and decided on the Leer 180XR with the high roof, and roof rack rails installed. Took about a month to arrive after order, but its exactly what i wanted.
12112174_902018053225582_6658502662912682118_n.jpg 12043066_902018116558909_8151961138832529981_n.jpg 12036730_902019403225447_6951835676716685944_n.jpg
Since i will be spending a lot of time in here sleeping and such, i ran (2) 12v outlets and a dual USB outlet to the bed, wired to the Aux battery, and always hot.
This pic is just a mock up, the wiring is done, but the box it still being refined! :)
12119116_904212953006092_414545977137316901_n.jpg 12109261_904430979650956_2536522980308662439_n.jpg
DT75FLH
I used the same system in my power wagon...the decked drawers with a cap....loved it, and liked how the drawers were only 200#....
character zero
dangerfoot
I like what you are doing with the tundra, I'm working on a similar setup for my 05. Been camping more, would like to just sleep in the back!
montypower
Adventure Time!
How tall does you platform sit above the truck bed? What is your head clearance from top of the platform to canopy? Like the direction you're going with this.
RAM5500 CAMPERTHING
Thanks.. A few more details to work out, but I think this is going to be the ideal setup for ME and MY needs. Hopefully I can give you some ideas. Feel free to hit me up with specific questions.
RAM5500 CAMPERTHING
Not sure why the platform pics didn't show up above. Weird.
It's 11" from bed to top of platform.
The reason I went with the high roof shell instead of the standard was that exact reason? So I could sit up.
I am 6'4" and can sit up comfortable and don't QUITE touch, but it's pretty close.
Thanks, more details and pics coming. Out of town and doing everything off my phone now.
montypower
Adventure Time!
What is the height from the top of the platform to the roof? Are there any other taller canopy options you considered?
RAM5500 CAMPERTHING
I'm not at home and won't be for a few weeks to measure it.
Like I said, I'm 6'4" and can sit in it comfortably without touching
As for taller, yes, they make a few taller ones, but they are TOO tall in my opinion and look really awkward.
cruiseroutfit
Supporting Sponsor: Cruiser Outfitters
Wow, long time no see. Congrats on the new build. And shop around before you think all the prices have gone up ;)
WonaWarrior
