VerMonsterRV
Gotta Be Nuts
A bit more work on the headboard. Still need to build the upper cabinet on the back wall (the square hole on the right top in the picture). The middle opening in the headboard will be for something framed, I have a couple of small adjustable flush lights on order for the top panel. The small cabinet on the top left will have a reading light and Hella fan mounted on the bottom, sort of the main reason for that cabinet. The doors will be 1/2" baltic birch plywood with the FRP skins (from the foam panel cutouts) bonded on with epoxy. The small inserts and bottom bit of the headboard have been done this way. If there is any condensation from the mattress I wanted FRP there to make it more durable.
As a bit of filler work while glues dried we mounted the freshwater pump under the kitchen sink near the 2 stage water filters. The pump is variable speed and although I have never used this brand we have a similar type of pump on the boat and it is practically silent (it is a few years old and has been discontinued and replaced with one with a "brain", which was a mistake on their part as we have had great success with ours and a friend had terrible luck with the new ones).
On a side note, I have talked with a local shop here about installing A/C in the cab. With the pictures from Joe917 we have a plan. He is recommending a "agriculture/heavy equipment" A/C compressor for 2 reasons. First is the seals are better (the compressor would be mounted under the engine) and some heavy equipment here in the USA is 24v. The estimate is $3200 installed, which does not seem too bad. I may have him install/fabricate the compressor and install the rest myself to try and save a bit of money. He is open to this but I need to find out roughly how much money it would really save, would be nice to drop it off and come back with it all working. They are also fabricators so may work on the rear tire/motorcycle rack and under body boxes.
