Looking for a mechanic recommendation in the Los Angeles area
nckwltn
What are of LA are you in?
I've done he valve seal job. It isn't that bad, just time consuming. That being he case, be ready to shell out a couple of grand for the work
Sent from my iPhone
Jay Ayala
1989 3.0L V6 Valve Seal Replacement
nkwltn is right. Its not all that hard but yes it is time consuming. I realize we have different vehicles (and different engines) but this will give you a good idea of what you should expect. This was my project back in April of 2014. It was performed on my 1989 Dodge Raider with the 3.0L engine. You may find this useful.
This gives you a good idea of the job in general and an alternative spring compressor tool. 1989 3.0l Valve Seal Replacement - Cylinder Heads Removed
This is a breakdown of the rope trick and how I did it for my 3.0l engine, yours is a 3.8l. 1989 3.0l Valve Seal Replacement - Rope Trick
This is how to service those hydraulic lash adjusters to avoid lifter ticking noise. 1989 3.0l - Servicing Your Hydraulic Lash Adjusters
FranklinDufresne
