I have a fairly superficial knowledge of electricity so I'm willing to try to fix things myself first, but this problem has me totally flummoxed.
I have an exterior light on my camper that works intermittently. I took the switch out of the circuit and the bulb lit up fine.
I then checked the continuity of the switch and found it to be fine, but I cleaned up all the contacts to be sure that wasn't causing the issue. I then plugged the light back in but it did NOT work, even though I am getting 12v through the circuit.
I tried an LED bulb in there too, but same issue. Why isn't the light working?
Thanks for your help.
