Jerry cans for fuel
lcavalletti
Hello all. I need about 15 gallons or three 5 gal Jerry cans mounted on my Yakima rack. What's the best deal and direction to go for these. I don't have the expensive aluminess box on the back so they have to go on my roof rack. So I may need to buy a basket or mounts for them or some kind of tie down. Need these for an upcoming Baja trip where it would really be best to have at least 20 gallons. But 15 might be ok
Recommended books for Overlanding
Into Africa
by Sam Manicom
From $24.6
Long Way Down: An Epic Journey by Motorcycle from Scotlan...
by Ewan McGregor, Charley Boorman
From $35.66
REDONE
[s]hard[/s]MEDIUM Core!
I'd just strap them on with a ratchet strap, but I'd put a tile of rubber flooring under them so they don't wear against the metal bars of the basket.
I agree that rotopax is a little proud for what it is. I don't even like taking my metal cans anymore for fear of theft. I just use the plastic 5gals.
guidolyons
Addicted to Gear Oil
lcavalletti
I added another cross bar underneath the basket making it three total I have the Yakima extended basket. I've actually stood on it without issue. According to Yakima Ist not approved but they said I could add a lot more weight than what's approved
. Now throw my inflatable kayak and my extra water cans with 160 lbs of fuel and I could be pushing it a bit. I would like to somehow fit the Jerry cans to the rear door if that's possible. Is there anything that mounts to my door or is it only bumper mount?
Oldcarnut
Not a place u want to run out of gas. Might go 20 to be safe. As for mounting, ratchet strapped to the rack works or if you have access to a sheet metal shop, have them build you a basket to mount off the back door and store there. Someone (forget who) is doing simiar on a bus build. Good luck.
REDONE
I completely agree with this. While I strap them to the roof, I have plans to build a hitch mount swing-away to put my spare and fuel on (the TH is also a DD, so I like it to look stock when not on an adventure). Mounting to a rear door sounds much more better!
Before becoming a mechanical engineer I was a fabricator, and if you draw it up, simple "dimensions and materials", most small fab shops would be happy to build it for you. Depending on how complex you make it, I'd imagine that $100 is right around the the target. The kind of small fab shop you're looking for will most likely be in the phone book as "welding/fabrication", but you might get a cheaper bid looking at "small engine repair", which tend to do light welding and fab, but without the overhead burden of carrying certifications like a true fab shop.
Actually the "best" place to put filled jerrycans is inside just behind the front seat (if rear seat removed) or behind the rear seat, for reasons of COG (center of gravity) and load distribution. Admittedly this is scary as far as having gasoline inside the car but new quality DeutscheOptik cans shouldn't leak. Put bulky low density items on the roofrack, like camping gear, folding chairs etc, lash them down well and cover with tarp for dust protection. Don't put cans inside car unless you have the metal ones that have positive sealing with a gasket and locking mechanism, don't risk leakage with plastic cans that seal only with plastic threads.
If you put 5 full cans on the roof you will absolutely feel the difference as far as handling.
If you do decide to put the cans on the roof, fill them at the last possible moment and empty as quickly as possible.
Reference: "Expedition Guide" by Tom Sheppard
Dreaming of Jupiter
by Ted Simon
From $15.36
Long Way Round: Chasing Shadows Across the World
From $14.59
Don't Go There. It's Not Safe. You'll Die.: And other mor...
by Jared McCaffree, Jessica Mans, Kobus Mans
From $19.99
Drive Nacho Drive: A Journey from the American Dream to t...
by Brad Van Orden, Sheena Van Orden
From $15.95
Motorcycle Messengers: Tales from the Road by Writers who...
by Lois Pryce, Mark Richardson, Carla King, Sam Manic...
From $9.99
Ray Hyland
I picked up a basic hitch-mount cargo basket for this purpose on one trip. PITA getting into the back, but it kept the weight of the fuel low and the fumes outside. The basket cost about $50 at Harbor Freight and I just ratchet strapped them down.
derjack
^^^ Pretty good deal
These NATO cans (with spout) are ~$80 https://www.topspecus.com/products/wavian-20l-5-gallon-steel-nato-jerry-fuel-can
Used NATO cans from Sportsman's Guide: $35 https://www.sportsmansguide.com/product/index/nato-military-surplus-20-liter-jerry-can-used?a=2146143
Scepter Military cans are very tough ~$40-$60 (used) $90+ new on Ebay.
Titan makes a pretty cool 12gallon tank that fits on an external spare (made for Jeeps, but could be adapted to other lug patterns)
These so called NATO Cans are just gas cans in Germany. That is maybe the reason why these cost in a hardware Store. https://www.bauhaus.info/messgefaesse-kanister/unitec-benzinkanister/p/12601971?q=benzin%20kan
Maybe because we give a **** about military stuff.
