nicholastanguma
Los Angeles, San Francisco
Whether it's the DRZ400 or the Jeep TJ or the Samurai or the Land Cruiser or the HD Sportster or any other vintage-to-almost-modern vehicle with a five speed transmission it seems like the majority of operators are constantly clamoring for a sixth gear.
Each one of these mills has much power potential hidden away behind the factory's lean carb settings, restrictive exhaust, poor head flow, and low compression ratio.
Everyone knows that such factory machines have to be strangled a bit, often in fact a lot of bit, to pass the emissions regulations for the markets in which they're sold, and so no factory engine is truly at its peak performance level.
But if an engine is operating at its best capacity won't it be making enough broad spectrum power from idle to redline that a 5 speed tran coupled with higher final drive gearing would essentially be the same thing as a strangled engine that has to use a 6 speed to compensate for the strangled power?
I've read plenty of instances where doods with a six speed tran are wishing for a seventh.
