Mashurst
I just got a new Jeep commander and I am working on putting together a plan for all the antennas I will need. This will be my first vehicle with HF. This is a jeep and while it is a bit of a mall crawler model, I intend to use it like a Jeep should be used. Three kids just don’t fit in the XJ anymore.
Anyway, the Transceiver will be a Yaesu 857d so it is tempting to get an ATAS 120 for it. My concern there is that it just will not last being hit by the occasional low branch and when it does take a hit is will be very costly. Another option is to get two or three hamsticks that can be swapped out (20m 40m and maybe 80m) and also run a tuner so I can use the other bands if I need to. If I snap one on the trail it is not a big deal. With the tuner the upfront cost of is about the same as the ATAS but in the long run it could be much less. Another way to go is with a 102” whip tuned with a tuner and possibly a base loading coil of some kind.
The trade off is that the ATAS is convent and does it all. The hamsticks/whip are a more robust system with some redundancy. In any case I think everything will be spring mounted.
I welcome any thoughts.
PS I will also be running an FT-7900 for VHF and a 5w HT with an external antenna as a dedicated APRS beacon.
