Here map app
craig333
Looks very nice. I was ready to download it until I read the permissions.
https://maps.here.com
Version 1.1.10172 can access:
Identity
read your own contact card
Contacts
read your contacts
Location
approximate location (network-based)
precise location (GPS and network-based)
SMS
send SMS messages
Phone
read call log
read phone status and identity
Photos/Media/Files
modify or delete the contents of your USB storage
read the contents of your USB storage
Storage
Wi-Fi connection information
view Wi-Fi connections
Device ID & call information
Other
install shortcuts
uninstall shortcuts
full network access
prevent device from sleeping
view network connections
change network connectivity
control vibration
pair with Bluetooth devices
access Bluetooth settings
Am I just a little paranoid?
Pilat
Tossing ewoks on Titan
Yes, you're a little paranoid. It can share your "favourites" (i.e. POI) via your login, and you might be able to sms/text your favourites too and so on. It can use both the GPS and the wifi connection for positioning, and it can share via both wifi and mobile network. The installing of shortcuts is boiler plate. It means you can favourite stuff as far as I can tell, and pairing and so on is also something you can do in the app. Most things are so you can do it in the settings, not that it will automatically create shortcuts, start pairing via bluetooth and so on.
MOguy
I have been using HERE for a few weeks and it works great. After I downloaded it set it to work off the Internet only. I am not sure what it does when WiFi is present.
HERE so far has worked great for me.
Havoceng
