SnoRnR
Hi,
I am in the process of purchasing the parts for my dual battery install. I installed the Shrockworks Dual battery kit. Toyota 4runner 2019.
My setup will be:
Odyssey PC34R-1500 68AH (34Ah usable)
Redarc BCDC 1225D
Blue Sea 6 Fuse Block
160w Renorgy Flexible solar on top of RTT
Deployable 100w solar blanket to supplement above when at base camp.
Switch Pro-9100 (Running AUX lights/loads and controlling compressor)
Blue Sea 12v USB/cigarette outlet in trunk.
Solar should supply 6-8 Amps for 6hrs = 36 to 48amps
Once static at camp will deploy 100-120W blanket ( 6-8amps)
Questions
1) Redarc states 6AWG wire for our cable lengths. (Would it be better to use 4AWG?) The Redarc will be mounted directly on top of AUX battery so seems overkill 4AWG. Also, states 40amp MIDI fuse for low resistance (Heat). (These things are huge) Would a 40amp circuit breaker or terminal mount fuse be ok?
2) I want to run 2 pairs of cables to the rear for the fridge and Blue Sea 12v/USB. The fridge will be direct to battery via Anderson connector in rear. Is 10AWG good for the fridge or overkill? Hoping for lowest amp loss/most efficient.
3) If I use 10AWG fro the fridge will it be ok with a 50amp Anderson connector? I know Anderson is made for thicker gauge possibly 6AWG.
4) Switch Pro will be mounted on the other side of the engine bay from the AUX battery. What size wire should I use? 2/4AWG? I know it's rated to 125A but would it ever draw that? Going from Blue Sea cable recommendation chart 2AWG would be required.
5) I will be making a mounting bracket for the top of the AUX battery (Mount Redarc BCDC plus 6 fuse Blue Seas block) Will any plastic board be good for this? Looking at HTPE or Acrylic on Amazon 1/2 inch thickness. Never done this before so don't know the tolerances (strength/heat) of these materials.
6) What gauge and how many wires can you fit down the windshield trunking?
7) Anyone have any ideas for a connection terminal for the solar (Plastic section at the base of the windshield corner) For connecting Anderson (solar). I may just run the cable into the hood then have Anderson connectors under there.
8) Is it ok to earth the AUX battery to the chassis/frame? Or should I run it to the starter battery? What size cable should I use for the earth?
I am thinking 12AWG to the Blue Sea 12v/USB outlet, mounted in the trunk.
My setup will be:
Redarc BCDC 1225D
Questions
