Hello all -
I'm looking at an ex-military 1017 that seems to have found its way through a stint in the US army before ending up on the market. Given the age and cloudy history of these vehicles, I wouldn't be surprised if it has a bit of a dog's breakfast of replaced parts.
I'm trying to determine what gearing/ratio was originally supplied in the driveline, and also if anyone has experience with parts procurement and/or cost for getting the axles upgraded to "fast" ones typically found on vehicles tagged for emergency vehicles. I'm looking at my local heavy truck shop for possibly doing the actual work, but I'd need to make sure I give them the correct set of parts before they dig into it as they've never actually worked on this specific model of truck before.
(Apparently these vehicles had at least three available ratios in the diffs, and when I went for a drive in this one the other day, even though the speedo was not working I could tell it definitely runs at "convoy" speeds, not "highway" speeds!)
I found the following numbers stamped on the axle casings. I'm not sure if they are complete, but the vehicle drives without the transfer case exploding, so presumably if we can determine one, they'll be the same for both F/R:
Rear axle casting: 675 351 0105 48
Front Axle casting (three number sequences in separate places): 381 331 0105 , 05 7 666 40 , DK044
The seller is unsure whether the vehicle was originally built as a 1985 or 1988 model - I'm uncomfortable to publicly list the VIN on the forum, but if anyone here has access to the MB factory database and I could PM them the VIN and engine IDs for any history, I'd be much obliged.
Thanks!
Thanks!
