Hard Reset?
I have a 2006 LR3 and the engine light came on yesterday on the way home from work, I had the codes read and at it is P0171 so I cleaned the MAF Sensor. Now I am wondering if I can disconnected the battery to reset the codes and see if that did the trick.
Is there a concern if I reset the codes this way?
Thanks
Abran
That will be fine.
A hard reset is more than just disconnecting the battery. You remove both cables from the battery, then jump a wire across connecting both cables. This drains the power in the capacitors so the memory is reset.
Ray_G
Just connecting the battery will not reset the codes. As Abran notes, the full hard reset procedure is a little more.
P0171 may plague you for awhile; worth considering something to update software (an IID tool) and at some point you may want to just get a code reader capable of turning off the codes (or one that both monitors and can turn off CELs, like a Scan Gauge)
r-
Ray
Thank you, just ordered...
iLAND Diagnostic Tool App Activation Kit And Bluetooth Adapter For Land Rover And Range Rover Vehicles (Single Vehicle Model Group)
norcalmaier
