cnutco
I have an '03 Limited that I bought from an older couple who never took it of road. This lady kept every receipt for everything she had done to the truck. Anyway she had all O2 sensors replaced sometime before I bought it.
I have had the truck for about 6 months now and have not done too much at all. The following has happened since I have had it.
The temp gauge does not work. This is a continued problem from last owner which they installed a new sender unit. I have been told that I would need to buy a new gauge and have the entire cluster reprogrammed which would be a min of $400.
Replace valve gasket covers due to leaking. Had new plugs and wires installed at the same time. The bank 2 sensor 2 O2 sensor code was on at this time too but it was new so we skipped it.
The light remained on and after the tune up the truck has started skipping only when accelerating mostly at top end.
So, we replaced the B2 S2 per the code. It was an OE Bosch sensor. After driving for only a short time the code came back on. The sensor is not reading steady and keeps dropping real low causing the code to come back on.
Any thoughts why the skipping and the O2 code is continuing?
