VIDEO:
Pix: https://postimg.cc/gallery/qqFnm51
Custom built heavy duty 60% rear seat delete with fridge slide 32" of full extension.
The fridge slide platform is 33 1/4" x 16 1/2". I strategically built in narrower so a wider fridge can fit centered on it with some overhang vs most fridge slides which are wider than the fridge and limit your ability to use a larger fridge in a rear seat due to limited door opening. I personally used this with a Dometic CFX 75DZW (shown in video)
Includes all hardware to mount using existing bolt locations on tacoma. I also fabricated a secondary support to prevent any torquing of the platform when the fridge is at full extension.
I will personally help you install this if picked up locally. Takes 15-20 minutes to get installed.
This was in a 3rd gen, but should work in 2nd gen as well. Double cab only (not access cab)
Price: $300
