paranoid56
SOLD
2003 Toyota Tacoma double cab Expo ready.
really love this truck, only selling as i needed to upgrade to a second gen to tow my FJ40.
This truck has worked perfect for me for years and will be sad to see it go.
$15,000 OBO
162xxx Miles
This should be most of the mods,
Front suspension
Camburg upper arms
Icon ext coilovers
spindle gussets
Rear Suspension
OME Dakar springs with extra dakar add a leaf
bilstine 12" remote resivor shocks on custom upper/lower mounts
Longer shackle
Poly bushings
Drivetrain
3.4 V6
J style transfer case
Dual stick (knob is backwards lol)
Automatic transmission
4.88 gears f/r
factory rear elocker
Manual locking front hubs
non ADD front diff
4runner TRD like wheels
255/85R16 Maxxis Big horn tires (brand new)
full size new spare to match tires on matching wheel.
Wheelers super bumps in rear
new Japan lower ball joints (less then 1k on them)
Tundra front brake upgrade with slotted rotors
1" diff drop
poly steering rack bushings.
1/4" thick rear diff cover
1.5 wheel spacers f/r
New belts (all three)
Ubolt flip
BPV bracket drop
Wheelers rear longer brake lines
Wheelers front longer brake lines.
axle relocate bracket.
Protection
Arb front bumper with alu hawse fairlead
Comeup 9500 winch with syn line (new never used)
thimble winch hookup
Full skidplating
Tube rock sliders
custom rear bumper with swing out, holds tire and two specter cans)
lighting
9" LED round lights on bumper
small led light bar on bumper (not hooked up, but works)
37.5" LED light bar on roof rack
Interior
Rear view camera
Seat heaters
dual band ham radio
Custom switch panel setup
OTRATTW laser etched switches
LED dome lights
LED map lights
LED red replacment lights for HVAC
Misc
Custom roof racks on cab and fiberglass top
custom internal support brace for rear roof rack
Integrated lights on internal support brace to light up rear area
Bed slide
Dual batery with large optima yellow top under bed of truck
Auto charging/disconnecting blue sea acr dual battery hookup
00ga wire for dual battery
dual battery gauge
Autometer transmission temp gauge (dual gauge holder with no gauge in second hole)
ViAir air compresser under hood
Hella supertone horn
Bluesea relay setup with custom holder
LED rear tail lights (full replacment ones)
Trailer wiring
LED dome lights
LED map lights
Large transmission cooler
Safari Snorkle
1" body lift.
Redtop optima battery
Grillcraft grill with TOYOTA lettering in the center.
ARB breather kit (front diff, transmission, transfer case, rear diff)
Proline hood struts
4' cb antenna
12v usb and cig plug in rear seat area ran off rear battery.
Some of the bad
4wd light does not work due to the new Jstyle transfer case (removed push button case but will include it)
Tcase is LOUD in 4wd but seems to work fine.
dual band ham the output for external speaker doesnt seem to work well (and speaker is behind rear seat, so kind hard to hear sometimes)
No ABS brakes (i dont consider this bad as i hated the factory ABS, but figured i would list it. this was due to putting in the front locking hubs and spindle. but will include the stock spindles if you want.
drivers seat has small tear in back.
Does not include tent or green mattrax
Will get more pics this weekend.
if anybody is at TDS this weekend It will be there also.
$15,000 OBO
162xxx Miles
Front suspension
Camburg upper arms
Icon ext coilovers
spindle gussets
Rear Suspension
Longer shackle
Poly bushings
Drivetrain
3.4 V6
4.88 gears f/r
non ADD front diff
1" diff drop
Ubolt flip
BPV bracket drop
Protection
Full skidplating
Tube rock sliders
lighting
Interior
Rear view camera
Seat heaters
dual band ham radio
LED dome lights
LED map lights
Misc
Bed slide
dual battery gauge
Trailer wiring
LED dome lights
LED map lights
Safari Snorkle
1" body lift.
Proline hood struts
4' cb antenna
Some of the bad
