asutherland
Coast Mountain Trailers Oasis 3 Overland Trailer, built in 2018. Last build of their line-up, it is a 5’ x 10’ trailer that weighs 1850 lbs without water. It has a unique eight foot wide full swing-out outdoor kitchen with a large, beautiful hand-crafted wooden counter, cabinets and drawers.
This unit is constructed on a custom steel trailer frame with independent axle-less high clearance A-arm suspension on Firestone airbags and shocks. The body is marine construction with a wooden superstructure fully insulated and sandwiched with Luan (3/8” water resistant RV skins). It’s fully clad in .040 smooth sheet aluminum and painted with industrial enamel. All adhesives and sealants are Sika Marine Grade / Waterproof and all hardware is stainless.
Inside it has a fully finished, hand-crafted interior with LED pot lights, cabinets and shelves, and double-sized bed with storage underneath.
It includes…
- Hot and cold running water with 12v electric on-demand marine pump
- 16 gal water bladder (tank) in basement storage area under bed to keep the weight low
- Hot outdoor shower via an Ecotemp L5 on demand LPG hot water heater
- Dometic CF-35 compressor fridge, 2 burner Coleman stove
- Axle-less high clearance CNC A-arm suspension with sleeved DOM tubing, designed and built locally at MetalMorphasis Fabrication in Kamloops, BC
- 31” All Terrain tires on steel rims (5 x 5 bolt spacing)
- Shocks and independently adjustable height air-bags
- Included Viair electric air pump
- Dexter electric brakes
- Emergency break-away brake system
- Full sized spare on side
- Removable / adjustable slide tow bar
- 3x aluminum military jerry can holders, two front one side
- 7-foot OZ-Trail awning on side with fully enclosed tent room. (clips to awning)
- Canadian designed Shady Boy 180-degree awning on rear, expands to cover the full swing of the kitchen
- Roof rack
Full electrical system:
- Charging via: 7-pin connector from vehicle, hard wired solar, and shore power
- 100 watt Renogy hard-wired solar panel with Renogy MPPT solar charger
- 6mo old deep cycle AGM Canadian Energy Discoverer Grp27 100ah battery in sub-floor. Expandable to two Grp27
- Blue sea distribution panel
- 1,000 watt pure sine wave inverter mounted next to battery with 4ga./100AMP resettable breaker, 110v on/off switch and outlet are in the kitchen
- Genius shore power charger / maintainer with exterior plug for shore power charging
- 12V cigarette and USB chargers throughout
- All LED bulbs inside and out
- Bluetooth stereo and speakers in kitchen
- 8 Bluetooth-controlled multi-colour rock/area lights hard-wired underneath (Full area mood lighting for parties in the wilderness!)
Extra set of brand new Dexter brakes, shocks, and airbags will be included. This is a complete and ready to go custom Overland / Offroad trailer that is as at home on the highways as it is on the trails. Ride height adjustable to suit your vehicle height, lightweight and can be towed by most rigs.
Located in Kamloops, BC Canada, and could deliver in BC. We had this trailer for just under a year but have decided it's too small for our family of 5. It's in excellent condition as it's only been used a few times.
$13,500 CAD
It includes…
- Roof rack
$13,500 CAD
