Tacoma front locker: True Trac or ARB?
Hi folks,
Here is my dilemma, I wan a front locker for the Tacoma but am torn between ARB and True Track. I know that most people here prefer the ARB unit but I feel that the True Track may be a great combo especially when combined with the selectable rear locker. Here is some additional information that should be factored into the thought process:
- I’ve got one selectable locker via the E-locked rear.
- The truck is used for hunting, fishing and camping and it is my DD.
- I encounter snow packed and icy roads regularly during the winter months. (This concerns me the most since a few have mentioned that this lead to problems during the winter driving season).
- Cost is important (I’d like to take the difference in price and put it towards an ExtremeAire compressor).
- I already have a spare front diff that I can use to install the locker in so that down time will be minimized and I have spare parts if needed.
- Officially there are no True Tracks listed that will work for the Toyota 7.5” front diff after 1995 (refer to attached .pdf file) but some people have successfully installed them in their Tacoma front diff (namely erin on this board). There may be an issue with the bearings provided with the True Track that would cause an issue with ADD equipped trucks, more on this below.
- It seems that the True Track is causing the front drive shaft together to turn constantly causing some drive line vibrations.
- According to what I have read, most people who have a front ARB locker don’t use it that often. It’s more of a peace of mind and safety mod.
True Track information
I did have some difficulty finding information on the True Track so to help out other members here are a few useful links:
Correct p/n for the Toyota 7.5" 27 spline front diff is 911A342 but it is for manual hub applications. Retail is in the $360 range. See
here for dealers:
Another point of interest from
this post (once you neglect all the banter and get to the good stuff) they say that the True Track may cause problems with and ADD equipped Tacoma due to the bearing design. To sum part of the discussion up: “
…once the new bearing is used, it will be a one part fits all for both ADD and non ADD, so effectively there would be ONE new part number for the TrueTrac LSD.…”
I was able to find one TrueTrack review
here .
Erin and I have been discussing True Tracks via PM. Erin has successfully installed front and rear True Tracks on his 2004 Tacoma with ADD. Here is some of the info that was shared:
… I'm very pleased with their performance both on/off road. They don't require tons of wheel slip before they work which was what I was after. Brake modulation works very well when you get a wheel in the air, though a bit tricky with a manual trans.
Be advised during wet/icy conditions, you must be careful how you drive through corners, or you end up going back towards where you came from. They transfer torque very efficiently…
…As far as the "noise", it really is a vibration from the front driveline predominantly, caused I think by the True trac being a full replacement carrier, which I believe is now turning the ADD side and spinning the front driveshaft full time, plus the added revs from the 4.88 gears, make the vibration apparent where as before it was not. It is not a bad vibe, but you can feel it nonetheless, more like a wheel that needs balancing, more apparent at some speeds then others.”
So I’d like to hear your thoughts and comments. Although after writing this down, I may have persuaded myself to go the ARB route (less issues & unknowns). I feel the discussion would be useful though.
Cheer :beer:,
P
Side note:
My spare front diff has 4.30 gears vs. my current 4.10. If you know anyone who has re-geared and had some 4.30 Toyota E-locker gears sitting around gathering dust, let me know!
