Yup, they weren't rotated often enough. You'll still get the feathering problem, with a breand new truck with a perfect alighnment. I have 2 Fords personally, and a dozen more Fords and Dodges at work. All do the same thing. DT's, XT Maxes, Toyos, Kelly, it doesn't matter.
Flip them if you want to, but not if you tow. You'll have to mark the rims and tires to put the tires back on correctly. Worn and feathered tires will not rebalence properly. They'll often trick the machine into instructing the tech to put weights in completely the wrong spots. I only balence MT's and the aggressive Hybrid tires once when new, never again.
